2001 focus fan doesn turn on.
FJ Gear Store
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Apr 2010
    02155
    26
    Default 2001 focus fan doesn turn on.
    relays are good. everything is connected.
    where should i go first.
    pull connectors and clean them or test the fans hard wired?
    not sure. any suggestions would be appreciated. thank you jetters
  3. #2
    Jan 2010
    Austin, TX
    845
    Default Re: 2001 focus fan doesn turn on.
    radiator cooling fans?
    If that's the issue check the fan resistor and wiring harness and replace both if burnt out.
    02 ZX5
  4. #3
    Apr 2010
    02155
    26
    hmmm sounds costly. i dont like that.
  5. Remove Advertisements
  6. #4
    Jan 2010
    Austin, TX
    845
    Its really not that expensive and minimal tools are required, there are a lot of threads here about it. Look between the cooling fans for a two wire connector plugged into the resistor. To disconnect it depress the metal clip, and pull to remove. Look for a burned out connector, as well as the resistor it plugs into. Contact Tousley Ford for parts or your local dealer.
    Post pics if your not sure
    02 ZX5
  7. #5
    Apr 2010
    02155
    26
    awesome thanks dee
  8. #6
    Apr 2010
    02155
    26
    my resistor looks burned. how much is the part?
  9. #7
    Jan 2010
    Austin, TX
    845
    I ordered mine from Tousley ford and it was around 40. Check the sponsors section and message them or give them a call tomorrow. If your wire harness looks burnt buy that too. I got my harness from the local dealer and it was double the cost.
    02 ZX5
  10. #8
    Apr 2010
    02155
    26
    my harness looks brand new but the resistor is either rusted or burnt. probably burnt.
    i ordered the resistor lastnight.
    i cant wait to be able to let my car idle. rofl
  11. #9
    Jan 2010
    Austin, TX
    845
    I know what you mean, took me several years to figure out what the problem was. You can turn on the ac to kick on the fans to bypass the resistor. I finally got sick of running the ac at stoplights and drive thru's every winter
    02 ZX5
  12. #10
    Apr 2010
    02155
    26
    i dont think they work with the ac on either? did i just buy this resistor for nothing?
    it looked ****ty anyways.
  13. #11
    Jan 2010
    Austin, TX
    845
    Let us know if it doesn't work, could be a bigger problem.
    02 ZX5
  14. #12
    Apr 2010
    02155
    26
    o jeez.... i just want to be able to idle for longer than 5 mins. wtf.
    hahaha its only getting hotter!
  15. #13
    Apr 2010
    02155
    26
    could it be a temperature sending unit or something of that sort?
    i tried it with the ac on today didnt seem to turn on. didnt hear anything.
    wiring is intact. and looks very undamaged.
    someone help me out here?
  16. #14
    Jan 2010
    Austin, TX
    845
    It could also be a fuse, maybe somebody else knows which one to check?
    02 ZX5
  17. #15
    Apr 2010
    02155
    26
    you think id be making a thread if i hadnt checked fuses or relays. cmon.
    this may be a focus forum but im not retarded.
