How Do I Replace the Blower Motor (Focus Stw. 2002)
FSWerks
Results 1 to 4 of 4
    May 2010
    Toronto
    12
    Default How Do I Replace the Blower Motor (Focus Stw. 2002)
    I am a new member, I've seen many posts from people with the same or similar issues: That is - blower only works on 4, not 1,2,3, the AC light comes on, but nothing happens.
    Checked the fuses, they are fine, I replaced the blower motor resistor and that fixed it, but it blew again two days later. I have been led to think it may be that the blower motor is drawing too much current, there is an issue with water leaking in or that I have a short somewhere.
    I managed to get a used motor cheap on eBay (hoping it doesn't have the same issue), but I don't know how to replace it. Can anyone point me to a site with instructions?
    Also... might be bad form to ask two questions... I wonder if there is a way to determine if the motor is drawing too much current?
    Much thanks in advance. I've only had this car a month, but I'm loving it. It's going to be a hot summer and I want AC.
  3. #2
    [FJ] Addict GapBoyPCS's Avatar
    Oct 2001
    11,255
    Default Re: How Do I Replace the Blower Motor (Focus Stw. 2002)
    Actually, it may not be the blower motor at all. It may be a simple resistor that's causing the problem.
    http://forums.focaljet.com/team-tech...-problems.html
    Richard
    2002 ZTS | Sangria Red |
  4. #3
    Apr 2010
    18
    I just did this on my car a few days ago. I'll try my best to explain it. There are three bolts underneath the glove box on the passenger side. take them off and remove the glove box. Then there is one bold right in front that holds in the feet air ventilation piece (it's only about six inches long and black plastic). Remove the piece. Get underneath whatever carpeting is there and theres the blower motor. Remove the electrical plug/circut, and then there are simply three bolts holding on the blower motor from underneath. Take them off and then your in business.
  5. Remove Advertisements
  6. #4
    Apr 2007
    Fort Wayne, IN
    2,548
    Replace the blower motor, and the resistor again. I have been saying that the blower motor takes out the resistor for years now with nay sayers and all. Ha see perfect example.
    '02 Liquid Gray ZX3 - Built NA, head, cams, tune.....SOLD
    '07 Black ZX3 - Intake and exhaust on SVT suspension.
    Currently building a forged 2.5 turbo to stuff in a Focus, Ranger or fox body.
