grinding on 2nd and 3rd gears
Rock Auto
Results 1 to 15 of 15
    Jun 2010
    louisville, ky
    24
    Default grinding on 2nd and 3rd gears
    i got a focus ZX3 from my brother because my le barons trany went out. and he bought it from a guy who said it was stuck in second gear. well we fixed that problem but now every time you shift it from 1st to 2nd or 2nd to 3rd there is a grinding of the gears. it sounds kind of like th clutch isnt letting go. yet when we bled the clutch there was no air. does anyone have any idea what might be causing this?
  3. #2
    Jul 2009
    Louisville, Ky
    198
    Default Re: grinding on 2nd and 3rd gears
    I am the brother. the car is a 2000 ZX3, MTX obviously. I installed a new shift tower (the upgraded/later style one so i still need to find a reverse switch connector) as well as a new shift cable end. so im thinking i may need to adjust the shift cables.
    TZT Performance.
    93 3000GT VR4
  4. #3
    Oct 2008
    Arkansas
    2,150
    thats a good idea on checking the cables, have fun trying to adjust them though. Thats one of the very few things I never want to do again on a focus
    I drive a stock-ish 05 gutted hatch. Occasionally bottle fed.
  5. Remove Advertisements
  6. #4
    Aug 2000
    24,330
    It can also be that the syncros are shot.
  7. #5
    Oct 2008
    Arkansas
    2,150
    lets hope it not that bad
  8. #6
    Jun 2010
    louisville, ky
    24
    well we will check the cables first if that isnt it then me might have to check the syncros, which will suck. unless someone has another idea as to what it might be that is causing it
  9. #7
    Jul 2009
    Louisville, Ky
    198
    did a little experiment today and while stopped, if i push the clutch in and try to engage 2nd or 3rd to quickly it will grind a little but if i wait for just a couple seconds it wont. im thinking the clutch isnt disengaging all the way immediately for some reason. air in the line/bad master/bad slave perhaps. will have to do some more digging.
    TZT Performance.
    93 3000GT VR4
  10. #8
    Oct 2008
    Arkansas
    2,150
    theirs a easy way to check the clutch if it isn't disengaging. put it up on jacks and put it into gear then press the clutch. if the wheels start rolling, well you get the idea.
  11. #9
    I
    Sep 2005
    Boston, MA
    13,333
    If you double clutch, does it grind? If not, it's probably the synchros. 3rd gear is notorious for going bad. Adjusting the linkage wouldn't hurt though:
    http://www.focushacks.com/index.php?...special%20tool
    Joe
    2013 Oxford White ST
    1985 Nimbus Grey Merkur XR4Ti
  12. #10
    Jul 2009
    Louisville, Ky
    198
    I know all about the MTX75 as i used to drive Contours. between my old turbo 97 Zetec and my old 00 SVTC i had almost 400K miles on the 2 MTX75 transmissions and neither of them ever had any syncro problems. of course ive seen plenty that do in the Contour world as well.
    i plan on getting it up in the air tomorrow to check some other things out and will see about checking out the clutch as well as the cable alignment while its on jack stands.
    Edit: when i installed the new cable end i set it just like that link says.
    TZT Performance.
    93 3000GT VR4
  13. #11
    Jul 2009
    Louisville, Ky
    198
    well, while sitting still with the engine running, if i push the clutch in and immediately try to go into 2nd it grinds, but if i wait for just a second or 2 it slides in without making noise. so, the syncros are shot which is why it doesnt grind after letting the input shaft spin down after disengaging the clutch.
    time to find a trans.
    TZT Performance.
    93 3000GT VR4
  14. #12
    Jun 2010
    louisville, ky
    24
    we pulled the trans and looked at the synchros and both the 2nd and 3rd gear synchros are shot
  15. #13
    Jun 2009
    125
    hmmm well look around there is always someone parting a fofo on louisville craigslist
  16. #14
    Jul 2009
    Louisville, Ky
    198
    we ordered a rebuild kit with syncros and i will be rebuilding it myself.
    TZT Performance.
    93 3000GT VR4
  17. #15
    Jun 2010
    louisville, ky
    24
    the car is done and running pretty good. not going to drive very far with it for the next few days
