2003 Ford Focus Won't start
FJ Gear Store
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
    Aug 2010
    16
    Default 2003 Ford Focus Won't start
    I posted this on yahoo which was no help
    I was driving on the hwy and the car just turned off. I tried to start it again but no luck.
    The car cranks but just wont start.
    -I reset the fuel pump switch, Didn't work
    -Tried to start it with starting fluid but nothing happened so its probably not the fuel pump
    -I replaced the spark plugs and wires , there seems to be spark
    I've checked the fuses,they're fine. The battery is also fine, so are the cables.
    -the cams seem to be turning normally
    I'm going to buy ignition coil pack to see if that does it. I'm waiting for them to be back in stock from this place http://www.1aauto.com/1A/IgnitionCoi...tm_content=ECI
    They cost 70 bucks at the parts store 35 bucks there
  3. #2
    Newbie
    Aug 2010
    2
    Default Re: 2003 Ford Focus Won't start
    Check the compression
  4. #3
    Aug 2010
    16
    How do I check that?
  5. Remove Advertisements
  6. #4
    Aug 2010
    16
    Someone on yahoo told me it could be the camshaft position sensor could that be it?
    Also whats the difference between the cam sensor and the crankshaft position sensor.
  7. #5
    Oct 2005
    Camp Hill/Shavertown, PA
    560
    Its not the camshaft sensor, that would not cause the engine to die / not start. A bad crankshaft position sensor though could cause the engine not to run.
    FYI you can buy or rent a compression testor at most auto parts stores. They are not difficult to use and will probably come with instructions specific to the kit. If not, here is a quick how to: http://www.2carpros.com/dia/how_to_c...ompression.htm
    '04 Infa-Red SVTF. #1772 of 1978, Born on 3/24/2004. Audophile, HID's, Winter Package, and some other things.
    '02 Steel Blue BMW 325i. 5 speed, winter package and no other things.
  8. #6
    Aug 2010
    16
    I think I'll try replacing the crankshaft sensor. If I can find it, I'll probably have to push the car onto ramps cus I think its near the bottom
  9. #7
    Mar 2007
    Moorpark, CA
    871
    A bad crankshaft sensor will cause it to die and not restart. If you're getting spark, it's probably not the coil or crankshaft sensor.
    What engine is it Zetec or Duratec?
  10. #8
    Aug 2010
    16
    Quote Originally Posted by lapp4sm View Post
    Its spi 2.0 L
  11. #9
    Junior Member EhbnerOhraa's Avatar
    Jun 2010
    Los Angeles, Killaafornia
    64
    I have the same problem with my 2003 SPI i had thought it was the alternator so i replaced it and still cranks and cranks but won't start replaced spark plugs and still no start now ima replace the coil pack and see what happens
    Note : The only time it doesnt turn on is when its cold out
    SMASHING IN MY SPI' LOS ANGELES
  12. #10
    Dec 2005
    A Brit in Montreal
    736
    goldse - I was about to say.... that looks like a big crack !
    Dato - And, if he still tries anything, use your l33t skills and un-dent his eye sockets.
    CheaperSleeper - Why the hell can't women just "ding" like a microwave?
    2003 fully loaded ZTW daily driver
    1986 Merkur XR4Ti, and 1978 Firebird Formula..another project
  13. #11
    Aug 2010
    16
    Quote Originally Posted by EhbnerOhraa View Post
    Its hot where I live and it just won't start.
  14. #12
    Aug 2010
    16
    Quote Originally Posted by Scorpion View Post
    Yeah. I haven't check compression or if the injectors are firing. It didn't start with starting fluid though. so I doubt its the injectors. Some mechanic also tried using starting fluid but he wasn't able to start it. He said it might be the fuel pump which I also doubt since it probably would've started with the fluid
  15. #13
    Senior TEAM Member 20focus03's Avatar
    Sep 2007
    ABQ,NEW MEXICO
    1,027
    check for codes?
    03 Sangria Red zx5 Recaro equipped :)
    "Honda Hunter-From x-games big air jump to 3 fat chicks scrape."
  16. #14
    Aug 2010
    16
    Quote Originally Posted by 20focus03 View Post
    check for codes?
    There was one but it just went away. I forgot the number. It doesn't show any codes
  17. #15
    Jun 2010
    64
    any updates?
