Location Of the Idle Air Control Valve...or IAC
Perfect Circle Autosport
Results 1 to 6 of 6
    Oct 2010
    26
    Default Location Of the Idle Air Control Valve...or IAC
    2002 Ford Focus ZTS DOHC
    I have searched the forum and have found many topic on the IAC valve, and everyone says that it is located on the air manifold, under the throttle body.
    I have searched the throttle body, and the air manifold and cannot seem to find it.
    I have read a couple threads saying that you could reach it from up top, and some saying you have to get to it under the vehicle.
    Does anyone have a good picture of the IAC valve attached to the engine so I know where to find it.
    Also should I find it below or on top?
  3. #2
    Senior TEAM Member CWCZX3's Avatar
    May 2001
    York, PA
    3,941
    Default Re: Location Of the Idle Air Control Valve...or IAC
    I stole this pic
    2000 Autumn Orange ZX3 "Beauty" Weekend Toy
    230hp 222tq@12psi 247hp 240tq@15psi Dyno Vids
    13.243@105.49 12psi June 06' Focus of the Month
    2013 Performance Blue ST Daily Driver
    2001 Flat Black ZX3 "Project River Rat" Sold
  4. #3
    May 2001
    York, PA
    3,941
    If you look at the mani pictured at the bottom of that pic you can see the iac just below the throttle body it's basically in between the manifold and block. i have removed mine to clean it and have always done it from underneath. It's a pia but doable from up top and not much easier from below. Hope this helps.
  5. Remove Advertisements
  6. #4
    Senior TEAM Member Tobyboom's Avatar
    Oct 2000
    Fort Worth, TX
    3,398
    Nm... beat me to it.
    FSwerks Tune on COBB Accessport, Steeda Intake, Cp-E Catless downpipe, DIY Front mount Intercooler, H&R Coilovers, MRR HR55 wheels 18x9, Breedt Shift Arm, Boomba RMM
  7. #5
    Oct 2010
    26
    fantastic....so its probably best to get to it from up bottom then....what size bolts hold that bad boy in?
  8. #6
    two 8mm bolts
