how to tell if your engine is seized?
Tasca Auto Group
Results 1 to 14 of 14
    Jan 2010
    13
    Default how to tell if your engine is seized?
    my focus wont start,its just clicks,wont turn over or anything,battery is good,12.75 volts,good ground as well,it happened today,before that,i tried to start the car a big grinding noise was heard, tried started again and it just clicks,
    i have a breaker bar and want to turn the engine over by hand,but i dont know which direction to go, please need help
  3. #2
    Senior TEAM Member COSVT03's Avatar
    Oct 2004
    Minneapolis, MN
    4,662
    Default
    Clockwise, take out spark plugs first.
    #3052 of 3985
    Full N/A SVT Build
  4. #3
    [FJ] Specialist norcalfocus01's Avatar
    Aug 2009
    MANTWEAKA, CA
    7,046
    Default Re: how to tell if your engine is seized?
    Sounds like your started is dead.
    Quote Originally Posted by sicko View Post
    if you increase the size of the gas tank and paint it black, it's an ak47 assault Focus
    Quote Originally Posted by Dracconix View Post
    I remember when your car was a brown scribble. Thank goodness we got you out of kindergarten and into a good art school. :thumbup:
  5. Remove Advertisements
  6. #4
    Jan 2010
    13
    ooops,it wont turn on clockwise direction so i went and turn counter clock wise, is it clockwise "me" facing the engine or clockwise front of the engine?
  7. #5
    Senior TEAM Member ladybug04's Avatar
    May 2004
    in the the mountains, Or
    2,734
    do self favor... hit self with breaker bar before turning engine with breaker bar...
    then take car to real mechanic, and have them replace starter
    Project pinky the crazy can corolla
    -04 focus(blown motor, waiting for donor and money)
    for sale: TC6 Factory team Buy it!!!
  8. #6
    Don't Call Me Gaga!
    Jul 2001
    30,266
    Clockwise at the front of the engine (passenger fender). Make sure you do it out of gear.
    I'm curious to see if this is the typical SPI dropped valve seat or something minor instead.
    I have too many cars.
  9. #7
    Jan 2010
    13
    Quote Originally Posted by ladybug04 View Post
    thanks a lot.. not helping though...
    this is what ive done so far,ive replaced the starter,replace the battery,and all it does now is just a rapid clicks,i replaced the starter relay found in the dash from the junkyard,check fuses are good
    only problem of mine is there is another ground wire located at the driver side right next to the ground of negative battery cable which i dont know where it is connected,but it appears it used to be the negative battery cable coz it has a battery connector splice on it.
    any suggestions what else to check? i stiil have not tried to turn the engine by hand because of some people here think they are so smart and dont think if the person have some money layin around to pay someone to fix their cars thats why i ask for ideas or suggestions,not to get mock and shut down
  10. #8
    May 2004
    2,734
    now that you explain that, try turning the engine by hand, if it does turn, check your grounds... one i know thats touchy is on the trans right by the starter... take it off, clean metal surfaces.. maybe some light sanding, and crank the bolt back down.
  11. #9
    Jan 2010
    13
    update:
    the engine is hydrolock,as i drain the oil a lot of coolant come out first then the oil,
    is it worth fixing it or buying a new engine will do?
    is the ford escort sohc 2.0 the same with ford focus spi 2.0? coz the junkyard close to me sayin their similar
  12. #10
    May 2004
    2,734
    just find a focus SPI, or find a focus with a pzev, or durtec thats been wrecked, and do a swap. more work yes, but the end result is a better motor. with more power
  13. #11
    Don't Call Me Gaga!
    Jul 2001
    30,266
    www.car-part.com is a great database for finding whole engines in your area. I've bought three or four that way.
  14. #12
    Jan 2010
    13
    i found a guy that sells and install rebuilt spi 2.0 for 1600,i did not get a chance to take a picture,the valve seat dropped on no 2 cylinder and pierced a hole on it,mechanic say nothing could be recovered as pieces went flying to the intake and exhaust valves
  15. #13
    Don't Call Me Gaga!
    Jul 2001
    30,266
    I kind of figured that.
    $1600 isn't bad for a complete R&R labor and engine rebuild, in the grand scheme of things.
    It'd be nice if they peen the valve seats into place so this doesn't happen again.
  16. #14
    Oct 2004
    Minneapolis, MN
    4,662
    ^ $1600 is a good price for not having to do the work - for a FULL rebuild & LABOR thats a GREAT price.
    #3052 of 3985
    Full N/A SVT Build
