EDM interior lighting... rear dome + vanity lights!
Capaldi Racing
Page 1 of 4 1234 LastLast
Results 1 to 15 of 50
    EDM Specialist CaysE's Avatar
    Nov 2004
    Dirty Jersey
    12,223
    Default EDM interior lighting... rear dome + vanity lights!
    This is what the interior looks like lit up with a Euro rear dome light installed with high power LED bulbs in both front and rear.
    This can be done with a Focus wagon rear dome light and harness, but I imported a harness from the UK that also has lamps mounted above the visors for the vanity mirrors.
    I'll start with the rear lamp first, since that's what most people will probably want to install. My car has a moonroof, so the shape and location of the rear lamp may vary a bit for non-moonroof cars, but the procedure should generally be the same.
    When you remove the headliner, this is what the top side looks like... notice the oval-shaped area towards the rear. This is where the rear lamp goes! Nice of Ford to give us a template.
    When you buy or salvage a rear lamp, make sure you get the mounting ring, and don't mess with the tabs too much! It's just a stamped and bent piece of sheet metal, and those tabs will break if you bend them too many times. Locate the ring on the headliner and mark it with a sharpie, with the longest tab towards the rear:
    Then using a sharp knife, simply cut the hole out. You want the trim ring to be tight to the headliner, so start small and then trim away the excess until the ring just fits, then bend the tabs down to secure it.
    Pop the rear lamp in with the switch towards the rear, and that part is done!
    The next step is the vanity lights if you have them. All they are is a molded plastic lens, metal mounting bracket and the bulb itself:
    Like the rear overhead lamp, there is a template molded into the headliner for these, as well:
    Just cut the hole like so:
    Insert the lens from the bottom:
    And secure the bracket:
    Voila!
    Finally you swap the wiring harness. At the front where it leads into the A-pillar, the harness and rear washer fluid feed tube are taped together with mounting tabs. Make note of the mounting tabs' positions and remove the tape. Replace the tabs if they're broken:
    Then just remove the OEM harness from the headliner (it is held in place with hot glue), and replace with the new one which, depending on your project, may be with or without the vanity lamps. Secure with hot glue.
    Reinstall your headliner and there's only one more Euro part to go... the visors! Yes, the visors are different when you have vanity lamps... the mirror covers are recessed with sliding doors for two purpose: first, so the visor doesn't accidentally switch on the lamp. And second, the normal flip-up cover would block the light from the lamp. Here's what you need:
    And that's it... you're good to go!
    2004 SVTf 3-door · Frozen White -- RS body conversion · ST coilovers
    2003 SVTf 3-door · Infra Red -- supercharged · 3" exhaust · EDM · OEM+ {FF ROTY'10 · FR'10 Best Interior · FR'11 Best Interior}
  3. #2
    Senior TEAM Member 20focus03's Avatar
    Sep 2007
    ABQ,NEW MEXICO
    1,027
    Default Re: EDM interior lighting... rear dome + vanity lights!
    Thats badass,i must do this
    03 Sangria Red zx5 Recaro equipped :)
    "Honda Hunter-From x-games big air jump to 3 fat chicks scrape."
  4. #3
    I Lost My Toy in Atlanta! glowin3232's Avatar
    Jul 2006
    Whorelando FL
    1,522
    Awesome! I've always been disappointed with the lack of rear lighting in my sedan.
    DD - '00 ZTS de-sexyfied and past her prime
    Racecar - '05 Mazdaspeed MX-5 #816
  5. Remove Advertisements
  6. #4
    TEAM Member Sniper Focus's Avatar
    Jun 2010
    Illinois
    985
    Nice! I did a rear dome with LED's in the front and rear too.
  7. #5
    Nov 2004
    Dirty Jersey
    12,223
    LED bulbs in the lamps:
  8. #6
    Junior Member Threctory's Avatar
    May 2009
    Lincoln, NE
    72
    Excellent!
    ~ 2002.5 Malibu Blue Zx3 ~
    I usually downshift when I'm near a Prius, so they can hear me hurting the environment.
  9. #7
    Senior TEAM Member 06ShadowGrey's Avatar
    Sep 2008
    Lewisville, TX
    1,424
    Where can I purchase the led for the front dome light? I currently have an led panel but want brighter...
    Quote Originally Posted by CaysE View Post
    It's a Honda, it probably had an aftermarket before the car was even available. A beforemarket.
    2006 DSG ZX3
    2012 Candy Blue SE
  10. #8
    Nov 2004
    Dirty Jersey
    12,223
  11. #9
    I'm a Neanderthal Robsteeler66's Avatar
    Apr 2003
    Somewhere, NJ
    625
    looks sweet dude
    My stable:
    2003 Sangria Red ZX5 Premium w/5-speed
    2015 Toyota Corolla S Plus
    2015 Toyota Sienna XLE
  12. #10
    Sep 2007
    ABQ,NEW MEXICO
    1,027
    whats all needed for the rear dome install
  13. #11
    May 2009
    Louisville, KY 40205
    633
    Quote Originally Posted by 20focus03 View Post
    1) A Focus
    2) A read dome light, or any other light that fits
    3) And wire. Several ways to wire it, just jump off the front and fish them back through the rear hole you cut it the simplest. Solder the wire to the appropriate spot up front.
  14. #12
    Apr 2011
    Royal Oak, MI
    121
    it looks like it's just the overhead light?
  15. #13
    Nov 2004
    Dirty Jersey
    12,223
    If you just want the rear dome light without the vanity lights, you just need the rear light, metal support ring, and the wiring harness above the headliner from a Focus wagon.
    If you want the vanity lights as well, you need to import the wiring harness, both vanity lights, both metal backing plates for the vanity lights, the rear dome light with metal support ring, and the sun visors with slide-open mirror covers from Europe. Most of this stuff can be found on Ebay.co.uk usually.
  16. #14
    Sep 2007
    ABQ,NEW MEXICO
    1,027
    Just the rear dome, the back of the focus is so dark, thanks
  17. #15
    Junior Member slickzx3's Avatar
    Aug 2009
    South Carolina
    75
    which ones are they...... 4210-xHP12-DI: 12 High Power LED Festoon Bulb or 4410-xHP12-DI: 12 High Power LED Festoon Bulb
