ford focus 2002 1.8 tddi endura engine how many oil litters
FSWerks
Results 1 to 4 of 4
    Oct 2010
    5
    Default ford focus 2002 1.8 tddi endura engine how many oil litters
    Hi there mates. I just changed oild before a few days and today when i check the level.. i see that oil is away from maximum.. i've been told that i must put 6 litters if i change oil filter as well.. but in my case i used 5.5 litters... today after the check i did, seems that even 5.5 litters are too much... 1 centimeter from the maximum point...
    what should i do? and what is the right quantity of oil that i must have inside my engine? thank you in advance
  3. #2
    [FJ] Addict GapBoyPCS's Avatar
    Oct 2001
    11,255
    Default Re: ford focus 2002 1.8 tddi endura engine how many oil litters
    Your owner's manual should outline how much oil you need to put in your vehicle.
    Richard
    2002 ZTS | Sangria Red |
  4. #3
    Oct 2010
    5
    Quote Originally Posted by GapBoyPCS View Post
    i check the book manual and says 6 litters but even in teh morning when i check oil on my engine i see that the line is up 1 cm from maximum point.. i also changed filter last time i changed oild.. my car works ok but i am afraid that it will do any harm to my engine... i run a diesel tddi 1.8 endura engine..
  5. Remove Advertisements
  6. #4
    Butt Face! Indecision's Avatar
    Apr 2004
    Prescott area, AZ
    1,560
    In my experience, a lot of owners manuals give a lower number than you actually need to put in. Typically 1/2 a quart. Go off the dipstick though. If you don't have enough, add some more.
    Carbon Fiber Driver Mod
    1966 Pontiac GTO 428CI/Muncie 4spd
    2003 SVT Focus EAP
