white smoke coming from my engine!?!?!?!?
Capaldi Racing
Results 1 to 14 of 14
    Jul 2011
    miami
    50
    Default white smoke coming from my engine!?!?!?!?
    I do own a ford focus zetec 2000 and I wanted to know how can I go about to fix this problem. I recently noticed a smoke coming from my engine, I opened the hood and I found out it was coming from my valve cover...it was all greasy and oily! I want to know how can I fix this? whats the specific part that I have to replace from this problem? Is it the valve gasket or the valve cover? Can someone guide me how to tackle this? And since my engine seems oily and grease because of that....how can I safely clean the oil spill from my engine? please help me! thanks a great lot
  3. #2
    Dec 2005
    A Brit in Montreal
    736
    Default Re: white smoke coming from my engine!?!?!?!?
    It's possibly the valve cover gasket. They are tricky on the zetec, because of the shape, and seem to leak if not fastened down right.
    You'd need to remove replace it really to make sure it's good. Not too expensive.
    Clean up the oil from the spark plug wells with kitchen roll. If there is water in the wells as well, don't panic! It's probably condensation.
    Once oil is cleaned up, you might want to change the spark plugs as well if they have not been done in a while. Don't buy any special ones - these engines don't need it.
    Once you're done, replace the valve cover gasket in the valve cover, and reinstall, tightening from the center out to the ends.
    I'd advise you to get a manual...Chiltons or Haynes...saves a lot of headaches.
    Let us know how it goes.
    goldse - I was about to say.... that looks like a big crack !
    Dato - And, if he still tries anything, use your l33t skills and un-dent his eye sockets.
    CheaperSleeper - Why the hell can't women just "ding" like a microwave?
    2003 fully loaded ZTW daily driver
    1986 Merkur XR4Ti, and 1978 Firebird Formula..another project
  4. #3
    Jul 2002
    New Braunfels, TX
    10,540
    you need a valve cover gasket. clean the mating surface very well and put a small dab of RTV in the corners of the half moons.
    TXFO V.2.0
  5. Remove Advertisements
  6. #4
    Jul 2011
    miami
    50
    Thanks for all the help! I will get the valve gasket tomorrow and will work on it too. SO you are saying that I have to change the spark plugs too? I havent changed them in a long time, so It would be a good Idea to do that. I will post how did it go.soon!
  7. #5
    Dec 2005
    A Brit in Montreal
    736
    You don't HAVE to replace the plugs...but while you're there, why not? Cheap enough.
  8. #6
    Jul 2011
    miami
    50
    can anybody send me the link of the right part I need to buy? It would be really helpful! also some good spark plugs that you guys can recommend me....
  9. #7
    Feb 2011
    41
    just go to the autoparts store they should be able to tell you the part and have it.
  10. #8
    Jan 2010
    medina ohio
    364
    you need a head gasket because coolant is getting into your cylinders causing the white smoke
  11. #9
    Jan 2010
    medina ohio
    364
    oh im really sorry i miss read the story yea its the valve cover gasket sorry about that
  12. #10
    I
    Sep 2005
    Boston, MA
    13,333
    Quote Originally Posted by 00focusdude View Post
    Go to Ford and get the Motorcraft gasket. The Felpro and other auto parts store gaskets will leak just like a bad stock one.
    Joe
    2013 Oxford White ST
    1985 Nimbus Grey Merkur XR4Ti
  13. #11
    Jul 2011
    miami
    50
    thanks for all your help everybody! I finally got to fix the gasket and also changed the spark plugs! I do have another problem with the revolutions of the car....when I am driving and hit the gas, the car seems to jump rpms for some odd reasons....do you have any idea what could be the problem?
  14. #12
    I
    Sep 2005
    Boston, MA
    13,333
    Is this an auto or manual trans?
    Joe
  15. #13
    Jul 2011
    miami
    50
    auto
  16. #14
    Senior TEAM Member Lancer211's Avatar
    Mar 2009
    Tucson, AZ
    3,294
    Quote Originally Posted by waddles09 View Post
    Unlikely.
    Quote Originally Posted by hEaT View Post
    I've had no problems with the Felpro VC gaskets? Granted, I have a Contour VC, rather than a Focus one.
    Quote Originally Posted by elragazzo26 View Post
    auto
    You have a tach with an ATX? Must be a ZTS, I presume?
    04 ATX Zetec sedan, FSW Cool-Flo, e2kIM, ported TB, header, TruBendz exhaust, SVT suspension, Steeda RSB, SVT FSB, FSW tune
    32" HDTV posted in Garage Sale!
    CarDomain Page
