Ford Focus Rear Drum Bearing Spindle Replace Repair Reuse Issues Lube?
FSWerks
Results 1 to 6 of 6
    Jun 2010
    Las Vegas
    49
    Exclamation Ford Focus Rear Drum Bearing Spindle Replace Repair Reuse Issues Lube?
    I like others have had issues with my rear brakes squealing. I decided to replace the rear shoes. My buddy did it for me, being a AES Tech so I figured he would do it best.
    He used a Impact driver to remove it and replace it the spindle nut.. I know bad Idea
    I did it once myself and know to remove the spindle 14mm bolts. So long story short.. no bad issues there but brakes still squealed. I found out that the common reason is there is a harmonic problem with the with the drum and other parts so I figured I would buy a new drum on ebay and it came with the bearing. $114 + $30 Shipping.
    Worked like a Charm, I did it myself. However 2 months later both bearing went bad.
    I tourqed the nuts to the 173lbs like the specs require. However I never added Extra Lube. Was told by a buddy that does this that its not needed. I figured he was right did not see extra lube when I removed it.
    So I went to Ford yesterday. Bought 2 new Drums with bearing since I do not trust the ebay drums.
    I know people say replace the nuts, but the washers looked perfect still my Focus is a 2007 with 65k miles. Unless someone can come up with a strong argument to replace them I cannot see why they need to be replaced.
    So.... to Review... here is what I know.
    Bolts 14mm on Spindle Tourqed to 49 ft/lbs.
    Spindle Nut I hear on forums 29mm 30mm and 32mm, I bought a 30mm seems every so slightly slacked but works well. so I think 29mm night be correct. and the torque spec is 173 ft/lbs
    Front Axle Nut - 32mm no idea on ft/lbs
    Rear Axle Nut - 29mm 173 ft/lbs
    So does the rear Spindles get Lubed when installing the rear drum with Spindle Nut Method. Or is the bearing sealed and pre-lubed????
    The new Drums have a SMALLER hub, so the 2007 drum speed ring will not fit the new drum I just bought they are smaller, forcing you to replace the Speed ring. I have pinched the old speed ring sides sightly and they seem to be working perfectly and holding..
  3. #2
    Nov 2004
    19,113
    Default Re: Ford Focus Rear Drum Bearing Spindle Replace Repair Reuse Issues Lube?
    I guess I'd really question what they sold you.
    The rear ABS tone rings were all the same from 2000-2010 and the drums were all the same from 2000-2009.
    You should have gotten the following part numbers,
    Drum 8S4Z-1113-B
    Tone ring 5S4Z-2B384-AA
    I just pulled a set off the shelf and verified that the tone rings do fit those drums.
    Now accepting online orders here http://parts.autonationfordwhitebearlake.com/
  4. #3
    Jun 2010
    Las Vegas
    49
    The set of drums I bought on ebay may have stretched them rings, but the main question is still here, does the spindle our bearings get lubed?
  5. Remove Advertisements
  6. #4
    Dec 2005
    A Brit in Montreal
    736
    My Chiltons for 2000-05 says nothing about lube anywhere, wither in drum/bearing complete replacement, nor bearing replacement alone.
    Only 2 things to note about drum replacement.
    1 is the tone ring for ABS if you have it...be careful with it.
    2 is to rotate the drum in the opposite direction when tightening the hub retaining nut to prevent damage to the bearing.
    goldse - I was about to say.... that looks like a big crack !
    Dato - And, if he still tries anything, use your l33t skills and un-dent his eye sockets.
    CheaperSleeper - Why the hell can't women just "ding" like a microwave?
    2003 fully loaded ZTW daily driver
    1986 Merkur XR4Ti, and 1978 Firebird Formula..another project
  7. #5
    Jul 2002
    New Braunfels, TX
    10,540
    no, do not lube anything. the bearing is a sealed bearing and does not require packing.
    TXFO V.2.0
  8. #6
    Jun 2010
    Las Vegas
    49
    well I bought a set of drums on ebay with bearing in them..
    I live in Las Vegas and drive my car like I stole it, I replaced the drum because the surface was to smooth and made noise.
    not because the bearing was bad, so I figured the spindle was fine.
    I installed the new set. they lasted 2 months. One bearing made noise then failed.
    Other one failed about the same time the replacement one came for the defective.
    I went to ford bought a new set, the ABS ring was sloppy, was wider then the OEM so that explains the sloppy ABS, but still got it to work.
    I got them to give me a refund on the drums.
    So I am out shipping on 3 drums.
    But all 3 failed. the Lube was all over the place with the failed drums, so I think the heat of las vegas killed the seals making the bearing fail.
    the Ford ones are 2 weeks in and still quiet wher ethe cheap ones failed in 1 week.
