car stalls when I stop it...!
Capaldi Racing
Results 1 to 6 of 6
    Jul 2011
    miami
    50
    Default car stalls when I stop it...!
    I have a ford focus 2000 zetec. I wanted to know what could be wrong with my car since it runs fine but wants to stall as soon as I stop it. Can anybody tell me what could be wrong? could it be a vacuum leak? and if its one...what parts I have to spray with the carb cleaner so I can notice a leak?, what other parts can I check that could make my car stall? DPFE? Intake manifold? hoses? please provide as much info you can....I really need lots of help since I use this car to go to work...
  3. #2
    Senior TEAM Member bflesher's Avatar
    Aug 2010
    Minnesota
    2,420
    Default Re: car stalls when I stop it...!
    You pretty much hit everything. IAC valve cleaning, DPFE Sensor and EGR Information , fuel filter changed, check for leaks in vac(with car running spray around with carb/choke, brake, MAF cleaner, if idle changes thats the spot). How many miles, man/auto?, how does the car run otherwise?
  4. #3
    Jul 2011
    miami
    50
    It has 190k miles! I have changed the fuel filter and spark plugs...also the cover gasket! I just checked for vacuums leaks and I havent noticed a idle change...what I have noticed was that the breather hose from the valve cover was disconnected..I plugged it back in but still the same stalling problem. I wonder what It could be now?
  5. Remove Advertisements
  6. #4
    Aug 2010
    Minnesota
    2,420
    Check the pcv hose it will collapse at idle. It runs from the front right of motor, under thermostat, around to intake under throttle body. When I noticed mine collapsing it was right after the 90 bend from the the intake.
  7. #5
    Jul 2011
    miami
    50
    yes! I already order the part online! the pcv hose or hose breather right?
  8. #6
    Jul 2011
    miami
    50
    I have changed the new pcv breather or pcv hose! and the car still stalls...do you have any idea what else could be? where else could I have a vacuum leak? just let me know if something please
