Brake Lights not working on a 2002 Ford Focus ZTS
Tire Rack
Results 1 to 11 of 11
    Feb 2012
    5
    Default Brake Lights not working on a 2002 Ford Focus ZTS
    I just bought a used 2002 Focus ZTS. After a couple of days, someone stopped me and said my brake lights are not working. After checking it out, my center brake light is working. It is the 2 on the sides that are not. I began reading online forums for help, I still have a couple of questions.
    Some people say it could be the GEM. Where is it located? Can i test it to see if it is the problem?
    I've heard you can unplug the brake switch and the brake light stay on. Is this true and where is that located?
    Or am I barking up the wrong tree entirerly?
    Any help would be appreciated.
  3. #2
    [FJ] Specialist norcalfocus01's Avatar
    Aug 2009
    MANTWEAKA, CA
    7,046
    Default Re: Brake Lights not working on a 2002 Ford Focus ZTS
    Check the bulbs.
    Quote Originally Posted by sicko View Post
    if you increase the size of the gas tank and paint it black, it's an ak47 assault Focus
    Quote Originally Posted by Dracconix View Post
    I remember when your car was a brown scribble. Thank goodness we got you out of kindergarten and into a good art school. :thumbup:
  4. #3
    Feb 2012
    5
    Quote Originally Posted by norcalfocus01 View Post
    Check the bulbs.
    I replaced the bulbs with new ones and no change
  5. Remove Advertisements
  6. #4
    Dec 2001
    SE Michigan
    844
    Next check for power and ground at the sockets to see which of the two you've lost.
  7. #5
    Feb 2012
    5
    Did that too. No power. I checked the fuse and it was good. I suppose it should be if the center brake light works.
  8. #6
    Dec 2001
    SE Michigan
    844
    I'm trying to pull up the wiring diagram, but they vary significantly depending upon content and body style. What body style (3dr, 4dr or wagon) is your Focus, and is it an automatic or manual trans?
  9. #7
    Feb 2012
    5
    It is a 2002 Focus ZTS. 4 door. It has 3 lights on each of the rear assemblies. Brake, blinker, and running light.
    It is also an automatic. If you have the wiring diagram and could share it, that would be awesome.
  10. #8
    Dec 2001
    SE Michigan
    844
    Send me a PM with your e-mail address and I can send you a PDF of it. I didn't see a way to send you a PM and attach a file.
  11. #9
    Feb 2012
    5
    Sorry for the ignorance. Whats a PM?
  12. #10
    Dec 2001
    SE Michigan
    844
    No problem. A Private Message. Click on my name then send me a Private Message with your e-mail address.
  13. #11
    Oct 2004
    Somewhere between UT and MN
    5,177
    how are your fuses?
    '00 Focus Beater Wagon
    Zetec - 5 speed - Rear Disc
