Replacement Hatchback Wiring Harness 2003 Focus SVT
Capaldi Racing
Results 1 to 11 of 11
    Newbie
    Jun 2011
    1
    Default Replacement Hatchback Wiring Harness 2003 Focus SVT
    This may have been posted somewhere else, so I apologize if this a repeat.
    I have been working with Steve from Tousley Ford on a hatchback wiring harness for my 03 SVT. The harness for the 2003 SVT shows as discontinued. However, the harness for the 2004 is still available. Not knowing whether it was the same or not, I took a chance and ordered it. Steve priced it to me for $52 +shipping. I have had the harness for a month, too hot here in Kansas. So today I decided to take a look at it.
    The first mistake I made, was thinking that the harness connected somewhere up in the headliner. It does not. It connects behind the sub woofer in the hatch. Unfortunately I had taken the entire left side loose before figuring this out Those crappy grab handles are a PIA.
    The hatchback harness is the grey one.
    Here is a picture of my old harness still in the car.
    I do a lot of repairs well, but fixing broken wires in a confined space is not one of them.
    This job took some time to get the harness out.
    Remove the plastic trim pieces in the hatchback.
    Remove the push rivets (2) holding the headliner up in the rear of the car.
    Remove the trim piece in the driver side rear above the small window behind the door.
    Remove the cover piece for the sub woofer.
    Remove the sub woofer, or at least move it out of the way.
    Remove the metal bracket that the sub woofer bolts to.
    Take screws out of driver side hatch parcel tray holder. (Black plastic piece that the parcel tray attaches to)
    Start removing the harness at the farthest connections.
    License plate lights
    windshield wiper motor
    ground connection
    white connector, not sure what it does, maybe the hatch solenoid
    Rear window defrost grid
    From there start pulling harness from the mounting points in the hatch. I used a needle nose pliers and a flat blade screwdriver to get any pieces left behind.
    Remove high mount stop light. I found it easier to remove wiper fluid hose by using a flat blade screwdriver and back it off of the assembly while still mounted. There is an access point with the hatch up to get to it.
    Disconnect the wiring harness from the high mount stop light.
    If not done already, use a flat blade screwdriver and work the rubber grommets out of the hatch side and the car side of the harness. Use the new harness for reference on where to insert the screwdriver to dislodge them.
    Pull harness most of the way out of the car.
    With the headliner dropped a little on the rear driver side, you can remove the wiper fluid hose at a connection point by the small window.
    The entire harness should pull out now.
    The new harness has two differences that I can see.
    1) there isn't a ground connection wire in this harness. The 03 harness had one that connected to the same ground point has the wiper motor.
    2) the wiper fluid hose is about 12 inches longer than the 03 harness. I just cut to fit. Make sure to orientate the little connector the same as the original. There is a check valve in the plastic piece and if it is going the wrong way, you will not have fluid to the rear wiper.
    Those are the only differences I could see.
    I installed by doing the reverse of above.
    I did not snap the grommets back into the car and hatch until I was sure everything was where it needed to be.
    Take care as to not twist the harness when routing it back into the hatch, otherwise you will kink the rubber protection piece between the grommets.
    I also tested everything before I snapped it all back together. To my initial frustration, the license plate lights didn't work. I then discovered a blown fuse. I imagine it had been that way for awhile. I quick trip to O'reilly's and it was in working order.
    I tested:
    windshield wiper fluid
    defrost grid
    hatch solenoid
    Finished product
    I hope this is helpful. Have a great day
  3. #2
    Senior TEAM Member COSVT03's Avatar
    Oct 2004
    Minneapolis, MN
    4,662
    Default Re: Replacement Hatchback Wiring Harness 2003 Focus SVT
    Thanks. This is a great write up for those who may need a little direction.
    Thanks for putting in the time for everyone else that may stumble across this.
    I do believe this would work on all trim levels as well.
    #3052 of 3985
    Full N/A SVT Build
  4. #3
    Newbie
    Oct 2012
    1
    Thanks for posting, my 2002 SVT hatch harness has a mess of cracked wires in the rubber flex-hose between the body and the hatch; I was debating doing a half-@$$ed repair on the wires, or pull the harness. Knowing it's a short distance to a plug (and reasonable cost) for the harness makes an easier choice to pull it.
  5. Remove Advertisements
  6. #4
    Aug 2012
    Canton, MI
    65
    Would you by chance have the part number for the harness? Just found out today my highmount stop lamp isn't working and low and behold the harness is broken at the pinch point.
  7. #5
    I
    Sep 2005
    Boston, MA
    13,333
    Quote Originally Posted by SVT 03 View Post
    If you shoot a PM to this guy, he should be able to get it for you:
    http://forums.focaljet.com/member.php?u=1012275
    That is who the OP ordered from.
    Joe
    2013 Oxford White ST
    1985 Nimbus Grey Merkur XR4Ti
  8. #6
    Newbie
    Jan 2012
    2
    Here is the part# for the 2004 wiring harness - 4S4Z14630BA. Hope this helps someone.
  9. #7
    TEAM Member 4rd Toys's Avatar
    May 2008
    In the Driver Seat
    232
    Quote Originally Posted by OrangeCrush View Post
    How did you confirm this?
    I've been trying to get a "straight" answer on this for some time, & watching the forum here, with no results.....
  10. #8
    FJ Premier Sponsor Steve@Tasca's Avatar
    Sep 2013
    12,413
    4S4Z-14630-BA is correct and we can still get it.
    http://www.tascaparts.com/oe-ford/4s...=4S4Z*14630*BA
    -Steve
    Tasca Auto Group, Here to make sure you get the best deals and an unsurpassed level of service.
    1-800-598-1484
  11. #9
    Newbie
    Jan 2012
    2
    Quote Originally Posted by Steve@Tasca View Post
    -Steve
    Ugh, I just put this harness in and not only is my wiper motor not functioning, but the once already warrantied latch assembly is not operational, as well. I started this whole project thinking the latch assembly was bad. I replaced it and that worked for a few weeks before the door open warning light came back on. I checked out the harness behind the rubber boot and it was pretty bad. I picked up this 2004 SVT harness and put it in last weekend. I checked conductivity at the end of the harness and that was good, however my latch assembly refuses to open and the rear wiper motor doesn't work. Both of these things worked with the original harness albeit intermittently. Ford won't warranty out the latch assembly again without me taking my car into them to diagnose it. Anybody have any ideas on how I can get the hatch open? I wish I would've bought the latch assembly with the emergency release attached. I think that one is meant for the wagon but I believe is still fits.
  12. #10
    Formerly focus_wrc Reza's Avatar
    Aug 2004
    Los Angeles
    7,418
    In case anyone else is searching for solution to this problem, I use this part 4S4Z-14630-BA to change the wires for my 2003 2.3D focus as well and everything works.
    Thanks to Steve for the part.
  13. #11
    Sep 2013
    12,413
    Glad it worked out Reza!
    1-800-598-1484
