NASA Spec Focus
Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > SPI Tuning
SPI Tuning Modifying the Split Port Injection 2.0L.
Old 01-07-2007, 10:31 AM   #26
Gigaherz
Default Re: SPI Aftermarket Parts & Mods List
Well since we now can edit really old posts again I started fixing a bunch of the links and updating things. I should have the list back in tip top shape in a couple of days. I think I fixed most of the first half of the links now.
One day, I will have an e-owl in my sig. On that day I will have "arrived".
Gigaherz is offline   Reply With Quote
Old 04-06-2007, 06:26 PM   #27
ras50401
my question is what is the better coil the msd the screamin demon or the accel?
ras50401 is offline   Reply With Quote
Old 04-08-2007, 11:53 PM   #28
ras50401
another great place to get free hacks and mods and things like that is focushacks.com
Old 08-13-2007, 09:02 AM   #29
v8FociDreams
v8FociDreams is offline   Reply With Quote
Old 08-13-2007, 09:49 AM   #30
v8FociDreams
Originally Posted by Gigaherz
The "Swab"(Super Waterboy Actuator Bypass)
Gotta thank H20boy for pioneering this mod. If you disconnect your IMRC motor from the intake manifold you can pick up some low end power. Here is a mini how-to he posted a while back..
"It's behind your stock airbox. Remove the airbox and a 10mm bolt on opposing corners holds the actuator on. It just slides off. Tuck it up out of the way or nytie it to the firewall, whatever. Open the butterflies (rotate the tabs toward the front of your car), and wedge them open with something. I have since changed to using an old carb spring to hold it open. Do not unplug the actuator, as you will get a CEL (or MIL) light. Drive like a bat out of hell. Enjoy. If you like the response, then e-mail me and I'll let you know what I did that's a little more permanent. " What I can add to H20boy's info is that I didn't remove my actuator, I put like five or six washers under it to space it away from the manifold enough that it doesn't touch the linkage arm anymore and still is bolted to the side of the intake manifold. Only thing to note here is you must only rotate teh tab about half way otherwise you end up closing the butterflies again and leaving them permanently shut with the spring.
Txfo's how-to with pics...
(Note:This is a special link that this ubb doesn't support so copy and paste the link minus the stars on the ends to make it work)
*****http://www.forumco.com/teamfocus/topic.asp?TOPIC_ID=418&FORUM_ID=8&CAT_ID=4 &Topic_Title="Free+HP"+how%2Dto+with+pics%21+% 28SWAB%29&Forum_Title=2+SPI+Performance*****
Ladybuf's EGR tube repair how-to
Has anybody done this lately with pics and detailed instructions? I would like to try this but it seems a little bit confusing.....
Old 08-27-2007, 01:48 PM   #31
razorfang
v8FociDreams, I could redo the swab and post picks if you still want... I personally didn't care to keep my butterfly open. We could use new links to clutch kits on here. Iv seen 4drfocus post some links up in another thread which could be used.
razorfang is offline   Reply With Quote
Old 08-27-2007, 05:31 PM   #32
H2Oboy
As author of said "SWAB", I am asking you to not perform this mod. It really doesn't do much for you.
Well, you'll burn more fuel........
Focus: Still running despite my best attempts, 7200 rpm shifts, and constant thrashing.
Thunderbird TC....Pushing 22 psi with a 150 shot!
Mustang LX 5.0 'vert...newest toy
On second minivan...wore the old one out!
H2Oboy is offline   Reply With Quote
Old 08-29-2007, 07:33 AM   #33
Red-SE-00´
.K-Sport .NRG .Progress .Carbon Creations .Yakima .Falken .Sportmax .aFe .Samco .Agency Power .Progress .Top Fuel .Kicker
.2006 .Scion .xB .Polar White
Honda Ruckus project coming soon!
[FJ] focaljet - GUIDELINES - GALLERY - [FJ]WALLPAPER - STORE - SPONSORS - SEARCH - Any Questions?
Red-SE-00´ is offline   Reply With Quote
Old 09-05-2007, 04:53 PM   #34
v8FociDreams
scratch that. I burn enough fuel. On my trip from Philly to Akron, OH (500 miles I used over 2 tanks of gas and one of my cooling fans ate itself.
Must be time for a good tune up.
Old 12-23-2007, 12:34 AM   #35
bigmac3
Newbie
http://www.forumco.com/teamfocus/top...8&CAT_ID=4 &Topic_Title="Free+HP"+how%2Dto+with+pics%21+% 28SWAB%29&Forum_Title=2+SPI+Performance
the above link no longer works (neither does the work-around forumco posted). Help?
60K '01 SOHC 4 dr Focus, bought new
once a Mech. now barely a parts changer :(
bigmac3 is offline   Reply With Quote
Old 03-13-2008, 12:05 AM   #36
ladybug04
alright ladies and germs, got info on clutches!!!!
spec stage 1
spec stage 2
both from c-f-m
time for an uodate!!!
exedy clutch from FS better then spec stage 1
Some
Over worked
Honda
Originally Posted by TXFO
ladybug04 is offline   Reply With Quote
