| SPI Tuning Modifying the Split Port Injection 2.0L. |
#1 (permalink) |
Is there any way to prevent those valves seats from dropping in our engines? I really don't want this to happend to my car, you understand why!
![]() from what I've read, it looks to be heat related, so I assume that It would be a good idea to keep the engine cooler.. so what would help? cooler thermostat? hot wiring the fans so we could turn them on with a switch for the hotter days? |
#3 (permalink) |
There's no need to modify the cooling system, just make sure it works. Test the ECT/fan, make sure to have the right coolent/water mixture, change your coolent with fresh stuff to slow internal corrosion. Yes, a over heated warped head can drop a valve seat, but some times they drop jus cuz they feel like it.
There might be some usefull info here: http://www.cardomain.com/memberpage/419565/4 |
#5 (permalink) |
OO here's some of my valve seat droppage
.http://im1.shutterfly.com/procserv/4...6108CbOGrds1Zi http://im1.shutterfly.com/procserv/4...6108CbOGrds1Zi http://im1.shutterfly.com/procserv/4...6108CbOGrds1Zi |
#8 (permalink) |
...the valve seat issue on Vin P engines is due to the PM valve seat inserts.IF you have replacement seats fitted be sure they are of the 'deeper' design and are the latest tempered design.The latest inserts also have a reduced leading edge chamfer wich gives greater contact area seat to head and better heat transfer from the seat.The contact area is the main reason for failure.If you have a head repaired be sure you use a machine shop that is an AERA member and be sure they work to the specs in the AERA Tech Bulletin # TB 1998 (July '02)(HMS Inc is an AERA Member)As a PS Be sure both the intake & exhaust manifolds are fully cleaned.Repeat failures have been experienced when parts of damaged seats/rings become stuck in the intake/exhaust manifolds ...the head is repaired but bits from uncleaned manifolds get back into the engine at start up.
#9 (permalink) | |
#11 (permalink) | |
Seen any thing cool in your day's? |
#12 (permalink) |
...worked of the Ford of Europe Sierra Cosworth engine prog...Did a bit with Cosworth on F1 engines...Ford Contour in USA (resident proto build eng)...bit on the MTX75 trans prog,had a good friend/fellow eng in Carrol Smith,Jack Roush cursed me a few times during the Contour prog...yeh,been 'round the block' a bit!
#13 (permalink) | |
#14 (permalink) | ||
But I'd still like to read a reply on that one! Welcome to SPI tuning, Kogbox King! Please stick around--you know your [censored] and we love you for it!
#15 (permalink) |
...so... from what I understand, there's no secret remedies for this issue unless your tear appart the whole head... so where stuck in something i'd call "the valve-dropping-spi lottery" ...
so all we can do is to keep our fingers crossed. |
#16 (permalink) |
...that just about sums it up...BUT if you want to save the pistons etc(and I know it's always $$$) you may get an old head re-manned correctly and swap em out...before the 'Big Bang'....The SOHC,like all engines has it's good & bad points...1000's of CVH's have given and still give great service...not quite like the 'ol pushrod 'Kent' engine that would still run well when the bores were so worn you could see most of the top ring.....!!
...but a good Ford 'lump' just the same. |
#18 (permalink) |
Newbie
I know this is an old post but I found it pretty hand and did a quick writeup about this, including some of the information from this thread:
http://mechdb.com/index.php/Valve_seat I even have pictures of how I dropped my valve seat on there, by using Seafoam! |
| Thread Tools | |
| Display Modes | |
