Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > SPI Tuning
SPI Tuning Modifying the Split Port Injection 2.0L.
Old 04-07-2008, 07:08 AM   #1
jbremount
Default PCV valve on 2003 Focus SPI engine
I am looking for the PVC valve on my 2003 Ford Focus SE with the 2.0-SPI engine. I pulled the hose and did not find a PCV valve anywhere near the valve cover. I followed the long hose all the way to the air box and there is a filter there. Where or is there a PCV valve on this engine?
jbremount is offline   Reply With Quote
Old 04-08-2008, 06:57 AM   #2
tin_maddog
Default Re: PCV valve on 2003 Focus SPI engine
If you are looking at your engine, it is located on the back to the right. There is a black hose connected to it.
211/211 @ 13 psi Yes, it is an SPI. Thanks Tom!
Who Watches the Watchmen?
tin_maddog is offline   Reply With Quote
Old 04-08-2008, 07:15 PM   #3
underconstruction
And it doesn't PULL out, it TWISTS out. WERD!
No longer a Focus owner. Now with two 5.0 Mustangs and a Thunderbird TC. So why am I here?? FKA "waterboy"
underconstruction is offline   Reply With Quote
Old 04-08-2008, 09:56 PM   #4
v8FociDreams
Funny. When I had my Focus, it didn't have a pcv valve.
Originally Posted by LamarWH
Is Dateline NBC even trying anymore? Must have been the new one.... "To Catch A Jackass"
v8FociDreams is offline   Reply With Quote
Old 07-10-2008, 09:32 PM   #5
Matt_Liq_Grey
I'm having the same problem. Is it located on the valve cover? There's just 2 hoses coming off the valve cove
R.I.P 2003 Liquid Grey 2.3 Duratec 1/4 mile: 15.47@89mph
>Mods: MM CAI, MM Balance shaft delete,Prothane lower mount,SVT suspention kit,MBRP 2.5" 2nd Cat Back
Matt_Liq_Grey is offline   Reply With Quote
Old 07-13-2008, 01:00 PM   #6
tin_maddog
It's the hose on the back right of the valve cover. Remove the hose. There will be a black piece still in the valve cover. Twist it out. THAT is the PCV.
Old 07-13-2008, 09:18 PM   #7
v8FociDreams
You mean the barb that the breather connects to? Thats not a PCV, its just a barb. (note U shaped rubber hose.) all it does is give somewhere for the breather hose to connect to.
Old 07-14-2008, 04:11 PM   #8
smurf_with_a_focus
Location: In the 804.. But still representin' the 417..
I believe he meant "back right of the valve cover" meaning the viewers right, not the cars right. Or in other words, back driver side of the valve cover.
Originally Posted by Maxximtl
How many pabst blue ribbons do you drink before this becomes a good idea?
2000 Infra Red LX, SVT front bumper, SVT upper grill, "euro" clear corners, SVT suspension, Invader CF hood, hood spacers, M3 mirrors, Matrix headlights, color matched door handles, factory Infra Red side trim, color matched trunk trim, painted interior trim, sedan tail light mod, split 5 spoke rims painted black, E.S. urethane dogbone inserts, 2&1/4" flex-back exhaust w/single glass pack, ported and polished stock exhaust manifold, modified Mustang GT throttle body, custom SRI, MSD coil, Massive wires, Autolite plat. plugs, A/C system removed.
smurf_with_a_focus is offline   Reply With Quote
Old 07-14-2008, 09:34 PM   #9
tin_maddog
Word.
It's just below and to the left of the ribbed area of the upper intake tube in the pic posted.
Old 08-17-2008, 11:16 AM   #10
aokrongly
Newbie
I have a zetec, not SPI, 2002, but my PCV valve is located on the right side of the engine (Front right) near where the radiator hose connects to the engine. It's about 8 inches below the Oil filler cap.
aokrongly is offline   Reply With Quote
Old 08-17-2008, 10:12 PM   #11
Scorpion
Ya, they are in different places...but then, so are lots of things.
I've arrowed it on the pic...easier.
Dato
And, if he still tries anything, use your l33t skills and un-dent his eye sockets.
CheaperSleeper
Why the hell can't women just "ding" like a microwave?
Scorpion is offline   Reply With Quote
Old 08-18-2008, 09:42 AM   #12
hEaT
There isn't anything on the block side, just on the VC? All the cars I've seen have had some sort of the valve cover breather and then the PCV coming from the block.
Tuned By: Bristol Dyno
hEaT is offline   Reply With Quote
Old 08-19-2008, 04:56 AM   #13
fungusfocus
Hey folks, one word of advice, the standard for describing Right and Left on a vehicle is the side of the car you would be looking at AS IF YOU WERE SITTING IN THE DRIVER'S SEAT. So when you say "left", it's the driver's side of the vehicle, "right" is the passenger. So when you go to a dealer or auto repair facility and say the noise is on the left, the service writer kows EXACTLY which side of the vehicle you are describing! This is the FIRST thing I taught my students in my GM technician classes!
John
'04 Corvette, '04 Mustang GT, '05 Escape, '97 F-250 4WD, '00 split port, '00 zetec, '03 RC 51,'81 CBX, '89 Hawk GT, '05 DR200E, '85 XL 600R YES, I'M A FORUM PIG!
fungusfocus is offline   Reply With Quote
Old 08-19-2008, 11:15 AM   #14
ladybug04
i dunno, i just say passenger, or driver side??????
Some
Over worked
Honda
Originally Posted by TXFO
ladybug04 is offline   Reply With Quote
Old 08-26-2008, 09:43 PM   #15
v8FociDreams
Can't do that. Would be too simple.
