But after it has run for 5 or 10 minutes and then stopped for a minute or more, it becomes hard to start and idles rough for 30 seconds and then it is OK.
I have changed the injectors, fuel filter, plugs and wires. Not sure where to go from here.
| SPI Tuning Modifying the Split Port Injection 2.0L. |
#1 |
Newbie
I have a 2001 Focus with 2.0 SPI and it has gotton hard to start when it is warm only. After sits over night it start nearly perfect except sometimes it take a bit extra to kick but idles smooth.
But after it has run for 5 or 10 minutes and then stopped for a minute or more, it becomes hard to start and idles rough for 30 seconds and then it is OK. I have changed the injectors, fuel filter, plugs and wires. Not sure where to go from here. ![]() |
#2 | |
try a seafoam treatment.
Some Over worked Honda Chewer Winner of AEMs dirty airfilter contest! AEM CAI! H&R Cup Kit, 17's Quote:
#3 |
does your coolant temp gauge seem to work fine?
One day, I will have an e-owl in my sig. On that day I will have "arrived". |
#4 |
When was your last oil change, and how many miles are on the engine? You may want to try adding one of those oil treatments for worn engines.
| Thread Tools | |
| Display Modes | |
