I have the mustang throttle body and I am using the instructions on this site to convert it. I am making my own adapter plates and I just noticed on the ones in the how to that there is a brass pin on the top plate that goes into the mustang tb. I was wondering if I need that b/c it has the cutout on the bottom of the tb that will flow into the tb intake. I haven't taken off the stock tb yet but i'm guessing there is a hole in the plate that will flow into the tube that goes into the side of the factory tb mounting plate. I'm just a little confused as to what all the holes that I have drilled into the tb for the air passages actually do.
Also is there any way to make the tps off of the focus work on the mustang tb?
Linear Mode
