Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > SPI Tuning
SPI Tuning Modifying the Split Port Injection 2.0L.
Old 06-30-2009, 11:39 AM   #1 (permalink)
Default 01 Focus SE and the Diabolical Clunking Noise - Motor Mount?
So I am getting this really nasty noise coming from the passenger side of the engine. I pulled the valve cover and everything appears to be in order there. Could this be the passenger motor mount? There is a clunking noise which follows engine speed. Also the car can barely move itself. You have to give it some throttle to get it to start, and I was about at WOT backing up my driveway.
If it is the mount, is this the part "Mount, focus, front - 2.0l sohc - 2.0L SOHC" on the Tousley page what I need? There is no exploded diagram for it. Car is an 01 SE w/ about 120k on it.
Thanks folks.
IlliniSTi is offline
Old 06-30-2009, 12:17 PM   #2 (permalink)
Tarderator
aka: Red-SE-00'
Default Re: 01 Focus SE and the Diabolical Clunking Noise - Motor Mount?
A motor mount wont cause it to have problems with going somewhere...that would be something in the motor.
any CEL?
New Project coming soon...xB is stock again.
.2006 .Scion .xB .Polar White
Team Sun*Works
[FJ] focaljet - GUIDELINES - GALLERY - [FJ]WALLPAPER - STORE - SPONSORS - SEARCH - Any Questions?
syntheticGT is offline
Old 06-30-2009, 01:21 PM   #3 (permalink)
No CEL's being thrown, none pending either.
Old 07-03-2009, 07:35 PM   #4 (permalink)
Motor mount? Ha! you wish it was that simple.
Sounds like a victom of valve seat drop.
212.2whp 262.6tq 1-7/8" Exhaust.
http://www.cardomain.com/id/jeffescortlx
1.9 SPI stock internals 2150lbs.
JeffescortLX is offline
Old 07-09-2009, 03:41 PM   #5 (permalink)
Hmm. Bent electrode on #3 spark plug. Looking more like valve seat drop.
Old 07-10-2009, 07:34 PM   #6 (permalink)
pzev04boy's Avatar
If you need a new piston when you get into the repairs, let me know. I have a stock pile of them & they are on backorder from ford.
03 Zetec ATX E&S TURBO SYSTEMS powered sedan
00 Mustang Gt - Built motor - Soon to be Single turbo
07 Ninja 500R Building 640cc race motor.
pzev04boy is offline
Old 07-10-2009, 07:55 PM   #7 (permalink)
Can't be a motor mount. Is it a clunking noise or is it engine knock?
SkoitchFocus is offline
Old 07-10-2009, 10:29 PM   #8 (permalink)
It's the sound of a valve seat bouncing around the cylender.
Old 07-14-2009, 12:02 AM   #9 (permalink)
Dropped valve seat in 2 and 3. Anybody know a good source for a used engine?
Old 07-15-2009, 03:13 PM   #10 (permalink)
pzev04boy's Avatar
The engine may not be junk. I just fixed one of these. It was cheaper to get new pistons & a reman head for it than buy an engine. The only thing to worry about is if the cylinder walls get damaged.
Also make sure that cylinders 1 & 4 don't have damage as well. I think what hapened is your cylinder number 3 dropped the seat and a piece went into the intake manifold and then into cylinder #2.
You can wet test cylinders # 1 & 4 by turning the engine so they are about mid way in the cylinder and then fill them with an inch of oil. If the oil is gone by the next day then those pistons are damaged too.
Make sure to get the rods checked as well. If you need any help sourcing parts let me know as it took a while to find a std piston set.
Old 11-03-2009, 10:15 PM   #11 (permalink)
OK, Looking for a little help here. Got a replacement motor, but I can't remember where all the hoses and such go. Check out the attached pics.
It's been so long since the engine was together I forgot where the pipe that runs across the top goes. Also there is another port on the valve cover that is a mystery.
Anything go into the bottom of the air box? I didn't think so, but could be mistaken
This hose is a coolant hose off of the water pump. Figured out where the other two hoses connect, but am missing this one.
Lastly on this one here, I'm wondering if anyone knows which ports are for what on the intake manifold. I've got two that right now have no hoses to connect to them.
TIA
Old 11-03-2009, 11:35 PM   #12 (permalink)
The hose going from the passenger side of the engine goes to that hole in the air box
marcusfranz is offline
