Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > SPI Tuning
SPI Tuning Modifying the Split Port Injection 2.0L.
Old 10-19-2009, 09:25 PM   #1 (permalink)
Unhappy spi intake man?
does any one know or tried to use a zetec intake manifold on a spi.i know that the the split port spacer but iv taken the butterflies and rod out and it runs great. so i figured if it works fine without it maybe i could just change the hol thing . any one try or know of any intake manifold swaps or mods.
p.s and im not talkin about the intake tube and filter the actual maifold thanks :0
sagon wagon me sagon wagon you :0
'hocus'pocus'focus'wagoon is offline
Old 10-20-2009, 01:32 AM   #2 (permalink)
SOHCTUNER's Avatar
Default Re: spi intake man?
I was going to do that but the holes are different you would need a new flange.
"it costs like 30 grand"
"you can buy a nice set of grapefuits for that amount of money"
"It's better than sex, I'm telling you."
"Just Stick that camshaft in there like a pro. maby we can stick them in there like pros LOL!"
SOHCTUNER is offline
Old 10-20-2009, 08:16 AM   #3 (permalink)
Tarderator
aka: Red-SE-00'
Holes dont line up and power gains would not be worth it.
New Project coming soon...xB is stock again.
.2006 .Scion .xB .Polar White
Team Sun*Works
[FJ] focaljet - GUIDELINES - GALLERY - [FJ]WALLPAPER - STORE - SPONSORS - SEARCH - Any Questions?
syntheticGT is offline
Old 10-20-2009, 08:18 AM   #4 (permalink)
ok thats what i was wondering. the header i have is for a zetec and that was the isue with that to so i welded the holes in the flange and redrilled them to fit. i wonder if i could do the same with the intake manifold?
Old 10-20-2009, 08:20 AM   #5 (permalink)
well i cant find a after market tb for the spi but only for the zetec.
Old 10-20-2009, 03:05 PM   #6 (permalink)
The Zetec intake mani is plastic with a built in O-ring. The port opening in the SPI head is no where near the same shape as the Zetec. It would be much easyer to build a intake mani from scratch rather then modifying the Zetec one.
But even if you did build a big mani with a large TB, your intake valve is still gonna be a bottle neck. So there wont be huge gains.
212.2whp 262.6tq 1-7/8" Exhaust.
http://www.cardomain.com/id/jeffescortlx
1.9 SPI stock internals 2150lbs.
JeffescortLX is offline
Old 10-20-2009, 06:12 PM   #7 (permalink)
pzev04boy's Avatar
Spi throttle body http://forums.focaljet.com/power/616...ttle-body.html
03 Zetec ATX E&S TURBO SYSTEMS powered sedan
00 Mustang Gt - Built motor - Soon to be Single turbo
07 Ninja 500R Building 640cc race motor.
pzev04boy is offline
Old 10-20-2009, 06:13 PM   #8 (permalink)
pzev04boy's Avatar
Would an old 1.9 escort GT intake manifold work with the spi head? I've never seen the ports on the 1.9.
Old 10-21-2009, 06:20 PM   #9 (permalink)
i will probaley just make my own intake from scatch and port the hell out of the intake runner :0
Old 10-21-2009, 09:36 PM   #10 (permalink)
The 1.9's have you average "O" shape. The SPI has a total of 8 intake ports in the head. 4 of them are crescent moon shaped.
SPI in too unique for a easy swap. Unless you keep the IMRC in place, that helps a little.
Old 10-22-2009, 01:22 PM   #11 (permalink)
[FJ] Addict
Expect no torque.
They shall not grow old, as we that are left grow old.
Age shall not weary them, nor the years condemn.
At the going down of the sun and in the morning
We will remember them.
Jimmy is offline
Old 10-25-2009, 11:15 PM   #12 (permalink)
pzev04boy's Avatar
I just wasn't sure if the port on the 1.9 manifold was big enough to go around the spi port. Is it the same bolt pattern even? Might be able to use it with the imrc still installed although I doubt it would give any gains doing that.
Old 10-27-2009, 07:34 PM   #13 (permalink)
Bolt pattern is different, and even with the IMRC the intake port shape is pretty differet.
