Ford Racing Performance Parts
Results 1 to 3 of 3
    Dec 2011
    11
    Default SPI focus an SPI escort ???
    first of thanks for reading an giving me advice..
    ok my car a 2001 ford focus with the spi soch engine (rod knock) but i found a great running 98 for escort engine from my buddies moms wreck escort , i know the cylinder head are no the same , so if i put my focus head(good head btw) on the escort block so the i can bolt the mount down, will it be able to work for my focus an will the tranny bolt to it... also will the axles work with the escort block thanks
  2. #2
    Mar 2003
    Saint Petersburg, Florida
    926
    Default Re: SPI focus an SPI escort ???
    The engines are twins in everything except bolt patterns. You can use the internals from the Escort block, but the block itself i'm pretty sure does not bolt up.
    Before the turbo-Max Power: 118.5@ 5250 RPM After: 164.3@ 5250 RPM
    www.escortsport.com
    Genuine ASE Certified Mazda/Hyundai/Isuzu Tech
    1997 Ford Escort 4dr "SPI" Turbo--JGStools.com manifold, E-bay 60trim turbo, fuel and timing management, TREPerformance.com 255lph fuel pump, diablo MAF.ia, 6PSI.
    2005 Focus Duratec 2.0 stock DD
  3. #3
    Dec 2011
    11
    thanks for the help man i though i had it in the bag lol, guess not lol thanks again
