Focaljet Store
Go Back   Focaljet - Ford Focus Forums > Focaljet Premier Sponsors > Steeda Autosports
Steeda Autosports A Ford performance legacy spanning nearly two decades.
www.steedafocus.com
Old 08-22-2006, 06:31 AM   #1
pocus
Default TB question
Alright I was lookingon your web site and saw under your FR intake manifold you should use part number161-M-9926-D462 for the TB. Were is this part. Is it just a ford mustang TB or what? I'm looking at buying a BBK 70mm TB for a ford mustang to bolt up to my FR intake mani if it will fit but I need to know if thats the case.
So is part # 161-M-9926-D462 a ford mustang TB and will a BBK 4.6L TB bolt up to a FR intake mani.
358whp and 335TQ-23psi-93oct. New E85 build in progress.
pocus is offline   Reply With Quote
Old 08-22-2006, 06:56 PM   #2
Honda Hunter
Default Re: TB question
The BBK unit's bolt pattern will match, as the FR intake uses the 4.6 bolt pattern, but you will most likely have to modify the throttle linkage hammer to clear the manifold.
I'll check the part number on the Ford TB for you and let you know.
Any other questions about this set up?
-Nick NaRdone
Honda Hunter is offline   Reply With Quote
Old 08-23-2006, 02:24 AM   #3
pocus
has the FR 70mm TB come out yet? Or how much is that TB that you have the part number listed go for?
I'm just trying to get a 70mm TB that will bolt up to my Intake and work properly.
Old 08-25-2006, 01:33 AM   #4
pocus
just woundering if you found out anything
Old 08-29-2006, 08:47 AM   #5
larryinfl
Hi Pocus,
I would recommend contacting our sales team directly. They would be be able to handle this question.
Thanks,
Larry
Steeda Autosports Webmaster :-)
Steeda Focus Goodness: http://www.steedafocus.com
Steeda Phone Number: 954-960-0774
larryinfl is offline   Reply With Quote
