NASA Spec Focus
Go Back   Focaljet - Ford Focus Forums > Focaljet Premier Sponsors > Steeda Autosports
Steeda Autosports A Ford performance legacy spanning nearly two decades.
www.steedafocus.com
Old 09-13-2006, 11:11 AM   #1
larryinfl
Thumbs up Power Slot 2005+ Disc Rotors Now Available
Hello Foci Fans,
Power Slot has just released front and rear slotted rotors for the 2005 and up Focus.
You can view all the power slot rotors and details at this link:
http://www.steedafocus.com/store/index.php?cPath=23_36
Steeda Autosports Webmaster :-)
Steeda Focus Goodness: http://www.steedafocus.com
Steeda Phone Number: 954-960-0774
larryinfl is offline
Old 09-13-2006, 01:49 PM   #2
paulhaskew
Default Re: Power Slot 2005+ Disc Rotors Now Available
since I know very little about brakes yet, how do these compare to the SVT brakes? or are they stock size?
2005 CD Silver ST-T - 322.7whp / 294.4wtq From the fallen ashes arose a beast...
Motive Racing
I, like God, do not play with dice and do not believe in coincidence. Words are the means to meaning, and for some, the annunciation of truth. And the truth is, there is something terribly wrong with this country.
paulhaskew is offline
Old 09-13-2006, 04:25 PM   #3
larryinfl
Yes, these are stock size. There are a couple benefits to these. One, the slotted rotors allow heated gas to escape from between the pad and rotor easier, increasing braking power. Another great benefit of these is that simply look much better than the rusty stock rotors, these will stay nice and silver and look very nice, especially if you have rims that show off your brakes.
Old 09-16-2006, 04:38 AM   #4
Under_rated
these look like the same ones FS sells. that are OEM quality...
is this true?
cause I need some rotors and I was wondering if they arent motorcraft the I need to pick them up!
Under_rated is offline
Old 09-18-2006, 11:31 AM   #5
larryinfl
These rotors meet or exceed OE quality. All specs as far as size and dimensions match OE specs.
I hope that clears it up.
Old 10-20-2006, 10:06 PM   #6
only_in_a_domestic
how much???
weight reduction= no sig:-)
only_in_a_domestic is offline
Old 10-21-2006, 08:53 PM   #7
tallguy2.3
less than 100, the link in the original post will tell ya
Cosworth Valve Springs for Duratec- STILL FOR SALE!
http://forums.focaljet.com/power/582...ml#post6572555
Crane Cams for Duratec
http://forums.focaljet.com/power/582...ml#post6572543
tallguy2.3 is offline
Old 10-23-2006, 07:24 AM   #8
john2195
i talked to Don(Steeda) a few days ago and he said they only had one set, that they used on one of their cars . . . i also talked to the sales rep for power slot and he told me early next year . . . so im thinking of going with the FS rotors . . . are they any good?
john2195 is offline
Old 10-23-2006, 07:25 AM   #9
john2195
if you call steeda, massive speed they'll both tell you the same . . . they're on order and not sure when they will arrive . . . ike i said above powerslot says early next year
john2195 is offline
