Exedy
Go Back   Focaljet - Ford Focus Forums > Focaljet Premier Sponsors > Steeda Autosports
Steeda Autosports A Ford performance legacy spanning nearly two decades.
www.steedafocus.com
Old 07-21-2007, 07:02 AM   #1
Mjasinski
Default Stewart Warner Ultra-shift lights
anyone know what is the process for installing this? http://www.steedafocus.com/store/Accessories-Stewart-Warner-Shift-Lights/c22_226/p558/Stewart-Warner-Ultra-Shift-Lights-(Blue)---'79-'04/product_info.html
what i like is the digi tach more then anything.
2000 Autumn Orange ZX3 "Op Orange"
2000 CD Silver ZX3 "Bullet" the beater
My Space
Mjasinski is offline   Reply With Quote
Old 07-30-2007, 01:14 PM   #2
larryinfl
Default Re: Stewart Warner Ultra-shift lights
I had to ask someone this question. This is the answer I was told:
"He would basically need a tach signal adapter to wire into the car, then the shift light would wire to the tach adapter."
I hope this helps.
Steeda Autosports Webmaster :-)
Steeda Focus Goodness: http://www.steedafocus.com
Steeda Phone Number: 954-960-0774
larryinfl is offline   Reply With Quote
Old 10-26-2007, 05:16 PM   #3
Terrible1
I use to have one of these. Just tap in to a hot and ground wire ( I tapped mine into wires in the headlight switch ) and then run the signal wire to pin# 48 on the ECU main harness
Easy as pie
ENGINE- Powerworks, OBX Header wrapped, 2.25 SS exhaust, Odyssey 680, Mocal oil cooler, Torsen, 4.06 FD, ClutchNet race clutch, Fidanza SUSPENSION/WHEELS- Custom H&R Coilovers, FS camber plates, Eibach sway bars, Rota Slips w/Toyo RA1's 225-45-15, SVT brakes w/Hawk race pads, ARP studs, Custom wheel spacers
EXTERIOR- Euro grills, Deft' CF hood, Sparco hood pins, CF F1 mirrors, CF sunroof delete, Custom front airdam/splitter
INTERIOR- Custom spec cage, RS shift knob, FC SS, Corbeau Fx1, Momo Mod78, NRG quick release, Defi gauges, Crow 5point SPONSORS- Troys Engine Mfg., Casper Customs
Terrible1 is offline   Reply With Quote
Old 12-26-2007, 05:58 PM   #4
SVTF
I've got one mounted in a pillar gauge pod and love it, I bought a tach driver when I installed mine last year sometime and it wasn't hard. At the time I didn't know about getting the signal from the ecu, but my ford racing tach driver does the trick.
03' ZX5 SVTF #2020 <---click
SVTF is offline   Reply With Quote
Old 12-27-2007, 01:42 AM   #5
Mjasinski
cool...and its digital gives an accurate read out? of rpm?
My Space
Old 12-27-2007, 08:13 AM   #6
SVTF
There are a few different settings within the gauge that interprets the crank position sensor signal differently if it was on a different motor (v6, v10, etc). If you just flip through them (theres maybe 4 or 5) its obvious which is correct because the rpm's are way off for the other choices.
They also have like 3 brightness levels and you can turn off the numerical display and just use it as a shift light if you like, and btw the shift light is bright.
Old 12-28-2007, 12:37 AM   #7
tallguy2.3
Yes I have one too and its probably something like 5 different brightness adjustments from noticeable to blinding. Mine is on blinding. I LOVE it.
Cosworth Valve Springs for Duratec- sold
http://forums.focaljet.com/power/582...ml#post6572555
Crane Cams for Duratec- probably sold
http://forums.focaljet.com/power/582...ml#post6572543
Infra Red 05 ST- Blown motor, waiting on more info
tallguy2.3 is offline   Reply With Quote
