Boston Acoustics
Go Back   Focaljet - Ford Focus Forums > Focaljet Premier Sponsors > Steeda Autosports
Steeda Autosports A Ford performance legacy spanning nearly two decades.
www.steedafocus.com
Old 07-21-2007, 07:02 AM   #1
Mjasinski
Default Stewart Warner Ultra-shift lights
anyone know what is the process for installing this? http://www.steedafocus.com/store/Accessories-Stewart-Warner-Shift-Lights/c22_226/p558/Stewart-Warner-Ultra-Shift-Lights-(Blue)---'79-'04/product_info.html
what i like is the digi tach more then anything.
2000 Autumn Orange ZX3 "Op Orange"
2000 CD Silver ZX3 "Bullet" the beater
My Space
Mjasinski is offline
Old 07-30-2007, 01:14 PM   #2
larryinfl
Default Re: Stewart Warner Ultra-shift lights
I had to ask someone this question. This is the answer I was told:
"He would basically need a tach signal adapter to wire into the car, then the shift light would wire to the tach adapter."
I hope this helps.
Steeda Autosports Webmaster :-)
Steeda Focus Goodness: http://www.steedafocus.com
Steeda Phone Number: 954-960-0774
larryinfl is offline
Old 10-26-2007, 05:16 PM   #3
Terrible1
I use to have one of these. Just tap in to a hot and ground wire ( I tapped mine into wires in the headlight switch ) and then run the signal wire to pin# 48 on the ECU main harness
Easy as pie
ENGINE- Powerworks, FC Header, 2.25 SS exhaust, Odyssey 680, Torsen, 4.06 FD, ClutchNet race clutch, Fidanza SUSPENSION/WHEELS- H&R Coilovers, LCR race camber plates, Eibach sway bars, custom strut bars, Rota Slips w/RT-615's 215-45-16 (street) Toyo RA1's 225-45-15 (track) SVT brakes
EXTERIOR- Euro grills, black painted headlights, Deft' CF hood, Sparco hood pins, CF F1 mirrors, sunroof delete
INTERIOR- Custom spec cage, RS shift/e-brake, FC SS w/custom base risers, Corbeau Fx1, Momo Mod78, NRG quick release, Defi gauges, Crow 5point SPONSORS- Troys Engine Mfg., Casper Customs
Terrible1 is offline
Old 12-26-2007, 05:58 PM   #4
SVTF
I've got one mounted in a pillar gauge pod and love it, I bought a tach driver when I installed mine last year sometime and it wasn't hard. At the time I didn't know about getting the signal from the ecu, but my ford racing tach driver does the trick.
03' ZX5 SVTF #2020 <---click
SVTF is offline
Old 12-27-2007, 01:42 AM   #5
Mjasinski
cool...and its digital gives an accurate read out? of rpm?
My Space
Old 12-27-2007, 08:13 AM   #6
SVTF
There are a few different settings within the gauge that interprets the crank position sensor signal differently if it was on a different motor (v6, v10, etc). If you just flip through them (theres maybe 4 or 5) its obvious which is correct because the rpm's are way off for the other choices.
They also have like 3 brightness levels and you can turn off the numerical display and just use it as a shift light if you like, and btw the shift light is bright.
SVTF is offline
Old 12-28-2007, 12:37 AM   #7
tallguy2.3
Yes I have one too and its probably something like 5 different brightness adjustments from noticeable to blinding. Mine is on blinding. I LOVE it.
tallguy2.3 is offline
Copyright ©2000 - 2007, Focaljet.com
