NASA Spec Focus
Go Back   Focaljet - Ford Focus Forums > FFSV - Ford Focus Specialty Vehicles > SVT Headquarters
SVT Headquarters Everything you need to know about the SVT Focus.
Old 08-15-2005, 11:19 AM   #1
blatch
Default Roof Rack for 3 Door SVT (Ham radio stuff too)
I need a roof rack for my SVT Focus. I was wondering where people have bought these before, because Google isn't much help.
Also, where have any of the HAMs on the forums mounted their antennas? I have mine on my roof, but I'm almost running out of room. Are there any good mounts that deal with the hatchback?
blatch is offline   Reply With Quote
Old 08-15-2005, 11:26 AM   #2
OverFocused
Default Re: Roof Rack for 3 Door SVT (Ham radio stuff too)
This was my post of a while back. This rack works well but was a lot of work to install. Removing the headliner is rather difficult.
Poster: OverFocused
Subject: Re: Thule Top Tracks on 2005 ZX3 Roof
I just finished installing a pair of Thule Top Tracks to the roof of my 2005 ZX3. These are high quality anodized aluminum pieces that accept the Thule Tracker Foot and crossbars. This vehicle is my daily driver and also has to be able to make the return leg of that trip to Home Depot. Now I can carry long lumber.
The installation was not easy. First I removed the headliner. Then determined that a side to side spacing of no more than 32 inches would clear all the roof reinforcements where the roof meets the sides.
I applied 2 inch wide blue masking tape and measured and remeasured and remeasured for six holes along each side. They match the holes in the track units. The rows are dead parallel. Drilling the holes was, well, a sign of commitment to finishing the project!
I placed the tracks closer to the rear as it seemed to look right and the roof curvature near the front is very extreme. These track units bend but only barely and really want to be installed on flat roofs. Follow instructions. I added larger diameter fender washers inside to spread the load. The tracks were cut to a 42 inch length.
I installed some sound damping material to that bare roof and will also be adding a thin sound mat. Next I will install the new overhead storage bin and rear dome light.
Views 6,7, and 8 in my album Focus ZX3 Project Images
http://www.imagestation.com/album/pi...0023&idx=5
OverFocused is offline   Reply With Quote
Old 08-15-2005, 11:30 AM   #3
blatch
Thank you very much!
Old 08-15-2005, 09:16 PM   #4
SuperHawk
Go to BAT and you can get the Euro one that is made for the Focus! It is the same one that is on the Kona Focus!!
www.batinc.net
Later Super
SuperHawk is offline   Reply With Quote
Old 08-16-2005, 05:00 AM   #5
McSVT
I have the BAT rack, it's just like the rack you will see on the Kona.
It does bolt to the car and I think it is very secure. If you are intresed in this rack you will need to check your car to see if you have the mounting hole on your car. The first place to check is in the front door section, if you look at the picture you will see about where to check. There should be 2 black plastic screws, they are under the weather stripping. In the back out near the outer edges of the hatch area there will be what look like spot whelds, it is actually some kind of calking. I drilled out the calking and then ran a tap into the nut that was welding in the car.
If I had a digital camera I would get some better pictures of it for you. The rack is rated at 75KG wich is I think about 160lbs. http://www.batinc.net/focus.htm sells them for just under $200.
McSVT is offline   Reply With Quote
Old 08-16-2005, 07:59 AM   #6
Black'02SVT
Ham radio: I have a maldol lip mount on my rear Hatch. I'll take a picture today and post it tonight.
Black'02SVT is offline   Reply With Quote
Old 08-16-2005, 02:16 PM   #7
PIRANHA
This is the ford accessory roof rack, made by yakima. It worked with my stock antenna, now i have a shorty antenna, but it does work with a socker.
Here is another pic
Also the rack is removeable, and it has locks to keep all your belongings secured while they are up there.
Hope this helps
LAZ
PIRANHA is offline   Reply With Quote
Old 08-17-2005, 08:00 PM   #8
Black'02SVT
I didn't see and radio pics so I thought I'd post my install.
here are a few of my antenna and mount...
And this how I mounted the remote face...
Without the mic plugged in there is plenty of room for the mirror to be adjusted. I have yet to 'remote' a mic plug and find a external speaker to my satisfation. Overall, I find the whole setup barely noticable from the outside (which I like).
Old 08-17-2005, 08:04 PM   #9
Black'02SVT
Oh, as far as racks go I've done fine with a removable hatch/trunk rack for bicycles. Skis and stuff I've put inside with the smaller half of the rear seat down. Personally I haven't had any further need than that.
Old 08-17-2005, 09:02 PM   #10
blatch
I posted in your other thread, but I thought I'd post here as well: what kind of antenna mount is that and where did you get it? I like it a lot better than sticking another mag-mount on my roof (that would total 5 on the roof)
Old 08-18-2005, 12:49 AM   #11
Black'02SVT
see my response there... other thread
Old 08-18-2005, 11:48 AM   #12
scsvtfocus
I have a complete set from Yakima with bike track on it as well. It looks better than factory, however, if you're concerned with weight you may want to look at Thule, but i don't if their system is much better. I'm happy with the system, but not with the costs. It "seems" every part i put on it seems to be always a $100.00 . I got the base set on trade, and it still probably have put another $3-350. As far as the radio stuff i have no idea. Good luck!
scsvtfocus is offline   Reply With Quote
Old 08-23-2005, 03:32 PM   #13
WD40
first place to check is in the front door section...
Front and rear (yellow arrow) mounting locations for the BAT/Kona Rack...>>>Clicky
WD40 is offline   Reply With Quote
