*WARNING* Following post may contain graphic images-Viewer Discretion IS advised.
***Do Not Buy ANY Plug besides the Denso Iridium*** Denso is the ONLY company besides Ford that sells the right spark plug for the SVT motor - All other spark plugs are VERY likely to cause engine damage.
***The aftermarket plugs are for the regular zetec engine and are the wrong heat range***
~If you dont believe me look up spark plugs and heat ranges and dagers on google~
*This thread does not apply to Ford -or- Tuner Companies* ~Be sure to contact them and order the right plug for your SVT~
I just wanted to let everyone know. In my never ending obligation to serve the focus community. If any of y'all keep track of me I tend to do a "little" bit of research on parts. Like my list of parts for the Quaife/Torsen install. (I dont think very many people really care because not many people have them. But that list has everything you need for the install) I have a friend with an SVT Focus that has run into a small problem.
Picture:
http://www.imagestation.com/picture/...b/efa168ef.jpg
Bigger Pictures:
http://www.imagestation.com/picture/...a/efa1689a.jpg
http://www.imagestation.com/picture/...0/efa16899.jpg
His new compression results are IN!!!
Cylinder #1 ~88LBS~ Cylinder #2 ~89LBS~ Cylinder #3 ~4lbs~ Cylinder #4 ~87LBS~
Aftermarket Spark Plug Line-Up
Ford Plugs -
SVT Part #AYFS092FECF4
DOHC Zetec #AZFS32FEF4
DENSO -
Iridium Part #ITV24 SVT Engine Vin-5
Iridium Part #ITV16 DOHC Zetec Vin-3
Bosch - Does not make ANY plugs for the SVT Focus
NGK -
Double Platinum Stock #2467 Iridium Part #PTR5A-13 SVT Engine Vin-5
Double Platinum Stock #2467 Iridium Part #PTR5A-13 DOHC Zetec Vin-3 (Non SVT)
Autolite -
Part #APP5364 & #XP5364 SVT Engine Vin-5
Part #APP5364 & #XP5364 DOHC Zetec Vin-3 (Non SVT)
Champion -
Iridium Part #9402 SVT Engine Vin-5 -
No part number for Vin-3 (Non SVT)
Split Fire - Part #SF514D DOHC Zetec Vin-3 (Non SVT)
No part number for SVT Engine Vin-5
Linear Mode
