| SVT Headquarters Everything you need to know about the SVT Focus. |
#1 (permalink) |
Edit: Track day results notes at bottom of this original post...
As part of my effort to make my SVT Focus a little more reliable for open track days, one of the changes happening is a retrofit to the power steering configuration. Colin Cantrell of Cantrell Motorpsorts is doing the work. He's about 1/2 done with the project, having completed the modified HP side with the replacement fittings. I've attached some photos. Here's the new line with fittings: ![]() It replaces this: ![]() Snipped here: ![]() Key new fitting (this fitting threads into the threaded opening on the PS pump and the receptacle end tightens over it; includes a metal crush ring at the pump): ![]() Top view of new hose assembled to stock line: ![]() Seems to work great so far in around town testing. And looks stock! Heh. This does require removal of the PS pump; Colin figures it to be a 2+ hour job if the you have a completed hose/adapter assembly. He's planning on offering this assembly to our community as a completed part with complete installation instructions. We're also putting on a small Mocal cooler. Colin might offer the whole deal as an option as well (cooler and adapter/hose) with complete instructions. My first day out on the track will be July 6. I'll keep you posted with updates on this thread. I'll add pictures of the PS cooler when it goes in. I have one of those infrared reading pyrometers. I'll see what kind of temps we encounter on the pump body; that's as close as I'll be able to get to reading temps from the PS system. June 21, 2006. As it turns out, we got the cooler installed last week. It is a Focus ATX cooler mounted low in front of the radiator (but behind my oil cooler). The thing is long (or wide depending on how you look at it). The car goes out for testing tomorrow at Pacific Raceways. --------------------------------------------------- Update: June 23, 2006: Some track day data. Got the car out yesterday (a little sooner than I originally expected) for a very pleasant track day at Pacific Raceways to assess the PS changes. I took three measurements after 2 sessions: Measurement points: * Power steering fliud in reservoir * Pump body (top) * HP fitting junction between new HP hose and original hardline Test Conditions: * First session: Following 2 cool down laps * Second session: Exited with no cooldown Ambient temp: ~65 to 70 deg F Equipement notes: Raytek MiniTemp (laser) pyrometer; Hoosier R3S04 tires. Driving style: Pretty much as I always drive; probably 8/10ths of what the car can do, with some areas of extended effort when working on specifics parts of the course. ---------------------------- First session results: * Power steering fliud in reservoir: 105 deg F * Pump body (top): 133 deg F * HP fitting junction between new HP hose and original hardline: 220 deg F Second session results: * Power steering fliud in reservoir: 134 deg F * Pump body (top): 159 deg F * HP fitting junction between new HP hose and original hardline: 219 deg F (also took a reading on the hardline for this session: 220 deg F) I think that's considerably cooler than the stock cooling loop would get, although I did not take measurements prior to the change (my bad). The Focus ATX cooler used for the job is a wide thing; it is set behind my oil cooler (which sits dead center behind the lower grill. We also kept the stock PS cooling loop. Other findings: No apparent leaking or seapage at the new connectors. I have several days coming up in July. Temps should definitely be at least in the 80s (maybe 90s) -- admittedly not a Pahrump or Willow Springs test -- but that's summer in the NW. What can I say? I'll post additional data as it is acquired.
Local HPDE calendar | get calendar tweets | money pit | in-car cams | SVT Focus parts4sale Last edited by mysvtftoy; 08-24-2006 at 05:42 PM. Reason: Edit: Some initial track day results |
#2 (permalink) |
Looks ok. Watch those compression fittings. Those have a tendency to leak after time. That is why it is illegal to use compression line splices for brake lines. If you flared the line for the fitting, that would be best. Not saying that this wont work, but just keep your eyes on it.
On a side note, why didnt you try and relocate the line alltogether? Using flexible hose you could have extended the line a bit and run it out of sight.
Black Aria...#1211: 2002 SVTF Jasmine...#1062: 2004 SVTF Euro Rain...1990 Ford Escort Wagon "Dear Diary...Jackpot!" Giggity Giggity Goo! |
#3 (permalink) |
So i guess you were having problems with your P/S fluid getting too hot? And this routes it further from the header to keep it cooler.
looks good
2002 SVT Focus - Borla catback, AEM shorty, Livewires, Screamin Demon coil |
#4 (permalink) | |
As with any critical system modification, we'll have to monitor this carefully over the months and years of abuse to come for Focustein. High pressure systems always run the risk of failure/leakage at their weakest points (connections). However, these particular parts are basically intended for heavy industrial equipment (like fork lift hydraulics), so I'm reasonably comfortable with the setup. And, to a certain degree, longevity depends in part on the operator doing the assembly. I'm glad Colin did this and not me. He's been doing this kind of ish on race vehicles for 20 years. As for location of the replacement HP hose splice, we opted to minimize the run length of the introduced hose as these things are prone to moving around a bit under load. And this baby is gonna get a lot of loading. Hah!
Local HPDE calendar | get calendar tweets | money pit | in-car cams | SVT Focus parts4sale |
#5 (permalink) | |
I have already switched to Redline PS fluid, which probably has helped, but with other cars of late experiencing the failure of this washer, I've been a little worried now that the car has 20+ track days on it. We replaced the entire adapter and this end of the line with the new 2-piece fitting and a metal crush ring. As for cooling, we'll be putting a small Mocal oil cooler in the return line. Reduced temperatures and (what we believe to be) a more stout fitting should reduce the likelihood of this particular type of failure. After this, I'm hoping it will be down to fluids, pads, tires, rotors, hubs, bearings, knuckles, rear spindles, light bulbs, and after track beers going forward (at least for a little while).
Local HPDE calendar | get calendar tweets | money pit | in-car cams | SVT Focus parts4sale Last edited by mysvtftoy; 06-01-2006 at 07:20 PM. |
#7 (permalink) |
Since you are using an infrared pyrometer, I suggest you measure and track your pump temp, fluid temp in the reservoir, and the Mocal temp before and after a track session.
I'm interested in your results too.
'04 PW (#1) Competition Orange SVT 5-door Euro Wanna buy a Focus harness bar? (<- click) |
#8 (permalink) |
The compression fittings to use are the two-ferrule design, such as Swagelok (or Bylok, Gyloc, Circlelok, etc - everyone makes knockoffs). If you use this kind you will have no problems whatsoever. Even McMaster-Carr has their version. Just be sure to watch materials - if your PS hardline is stainless or carbon steel, you will have to use a stainless or carbon steel Swagelok fitting or else it won't "swage" the tubing. You can't use a brass fitting and ferrules on a carbon or stainless tube.
Make sure you debur that tubing ID!!!!
'02 Sonic Blue SVT #504 |
#9 (permalink) | |
I would like to note that my PS failed in regular city driving 3 times over 2 months. Nothing like making a slow speed turn and being greeted by smoke coming out from the wheel well and under the hood. Fun stuff! That piece looks good and I hope it works well.
Your friendly local NREMT-B, WEMT, CHT (IT) '08 Ninja 250R, '71 240z |
#10 (permalink) | |
Local HPDE calendar | get calendar tweets | money pit | in-car cams | SVT Focus parts4sale Last edited by mysvtftoy; 06-02-2006 at 12:56 PM. |
#11 (permalink) | |
#12 (permalink) |
Nice. This is a cool fix/precaution. I'd like to see how much this "kit" would cost with the cooler as well.
Brian Hult Founder HTPerformance - Premium Performance Parts. Committed to Design Excellence. 30 First Street, Unit #3 Bridgewater, MA 02324 Ph: +1.508.659.4466 E: brian@htperformance.net Follow me on Twitter: http://twitter.com/HTPerformance Follow us on Facebook: http://www.facebook.com/pages/HTPerf...ET/32467520987 |
#13 (permalink) |
Coolers can be really cheap for the PS application, even the stacked plate design. Summit has a bunch. Hayden makes a bunch of stacked plate tranny coolers that you can buy at places that sell trailer hitches. $30-$50 will buy you the complete kit.
The hard part is finding the right places for your PS cooler and your oil cooler, without ruining your A/C in summertime Atlanta traffic...........maybe I could screw on one of those big ricey wings and mount my coolers on it!! (finally a use for those things!)
#14 (permalink) | |
The PS cooler will be small, so we figure to attach it behind the opening where the passenger-side fog lamp used to be. We'll just put a little bit of mesh in the fog lamp opening to reduce the likelihood of rock smashage on the cooler.
#15 (permalink) |
That's a good idea for where to put the cooler. I don't have fogs anyways, and that makes sense. Driver side for CAI, pass for cooler(s) . Schweet.
#16 (permalink) | |
Local HPDE calendar | get calendar tweets | money pit | in-car cams | SVT Focus parts4sale Last edited by mysvtftoy; 06-06-2006 at 12:58 PM. Reason: typos, typos, everywhere I look typos. |
#17 (permalink) | |
#18 (permalink) | |
While the oil filter does block the radiator a bit, I'm seeing lower overall operational coolant temps and MUCH lower absolute coolant temps with the oil cooler vs. no oil cooler.
#19 (permalink) |
Minor update: PS cooler is on hold. We're going to run the car with the stock PS "cooler," Redline PS fluid, and this PS pump adapter/HP line retrofit for now. I'll post any temp readings once I get to the track (July).
#21 (permalink) |
[FJ] Addict
I'm curious... why this retrofit??? I'm not seeing what benefits you gained from it.
You still have the line directy over the header, you just have some better fittings in place, however instead of one consistent hard-line you have multiple fittings which are now areas for possible failure. Did you put in a cooler or something? I'm looking to get this done immediately, but I want to remove and completely relocate everything under the car and out of the way.
Current: John Cooper Works Mini Cooper Clubman Former owner of Turbo Miata Former owner of Turbo SVTF |
#22 (permalink) | |
I'm going to drive it around the street a bit and do some limit to limit turning to see if I can get it to leak. Cooler might go on before track days start; or somewhere in the middle after the first couple. Still TBD.
#23 (permalink) | |
The reasoning for the setup as is was that Colin figured it would get the job done and involve less overall movement under load. It might change, we'll see.
#24 (permalink) |
Some initial track day results added to original post.
| Thread Tools | |
| Display Modes | |
