Tasca Auto Group
Results 1 to 11 of 11
    Mar 2005
    Hawaii
    7
    Default 2005 Focus front axel problems?
    Has anyone had front axel problems? My ZX5 is only 4 mo. old and has had the right front replaced - still makes noise - going back to dealer Monday - sure would appreciate some feedback before then!!
  2. #2
    Feb 2005
    10
    Default Re: 2005 Focus front axel problems?
    i have a 05 zx3,i have not had problems.maybe just ur zx5.i have race it about 12 time.YES go back 2 the dealer one time if it still make noise, tell i want a new car. r u put money in the zx5
  3. #3
    Apr 2004
    Buffalo, NY
    351
    I couldn't really make out the last 1/2 of that response. The lemon law sates that the same problem must come up 4 times to qualify. I just got my ST 2 weeks ago and read the lemon law form you have to sign.
  4. #4
    Don't Call Me Gaga!
    Jul 2001
    30,122
    If you have a bearing type noise on the center/right, it could also be the intermediate shaft carrier bearing. At one point it was a semi-common failure, but it has been years since then. An entire new right side axle and intermediate shaft assembly should solve the problem... and the part only costs Ford around $120.
    ..if that is the problem.
    Either way, the 2005 Focus front axles are the same as all 03 and 04 Duratec equipped Foci, so I don't feel this is a line problem so much as just a single vehicle.
  5. #5
    May 2002
    Arcata, CA
    780
    What kind of noise does it make?
  6. #6
    TEAM Member microtonal's Avatar
    Sep 2003
    Seattle, WA
    883
    I'm assuming it's some other than the very noisy GY Eagle tires.
  7. #7
    Jan 2003
    Lubbock, TX (my once and future--but not right now--home
    5,446
    a couple of other durateckers had this problem if i remember correctly.
  8. #8
    Feb 2005
    10
    maybe ur right and Duratec's do RULE
  9. #9
    Mar 2005
    Hawaii
    7
    That's it in a nutshell - ironic aside: the first rental they put me in was a bottom-of-the-line Focus zx3 - It's now in the shop 'cause it had the exact same noise mine has!! Well, we'll see what happens after Monday - I've printed out the Hawaii Lemon Law and the advise I've found on this site - sure hope it doesn't come to that, though - I really LOVE my banana boat!! Mahalo Nui for the input!
  10. #10
    Oct 2004
    85 GTI 86 GTI
    1,566
    they arent noisy
    they do seem to be made of plastic though
  11. #11
    May 2002
    Arcata, CA
    780
    Are you sure it's not the noise almost every mtx-75 focus has? The gear noise a low rpms.
