Capaldi Racing
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
    Nov 2000
    Berwick, PA , USA
    124
    Default Check engine light!
    just going down the road with my 2001 ZX3 (5,000 miles on it) and the check engine light has come on, anyone on here experience that on such a new car?
  2. #2
    Aug 2000
    San Antonio, TX
    8,481
    Default Re: Check engine light!
    I'd take it to the dealer to let them check for codes.
  3. #3
    Nov 2000
    Berwick, PA , USA
    124
    Codes? what do you mean...sorry Im not a mechanic type so bear with me.
    My wife was going down the road right past the dealers, so she brought it in instantly.
    Its not a red lite, but the organge check engine lite that is on. They cant get it in until friday. They said its completely safe to drive in the meantime.
  4. #4
    Mar 2001
    (Leo) Long Beach / Glendale , CA. USA
    277
    Its a stupid reminder for you to change your oil. My GF's cougar does the same Shiz. Mine focus only has 2000 miles so I haven't gotten it yet. If you take the car to ford to change your oil, they'll reset it. If you change it , drive it for about 100 miles and it'll prolly turn off.
    I started my car w/ a loose ignition wire, light came on. Stayed on after I fixed it, and reset like 100 miles later.
    Pitch Black 2001 ZX-3 to Match My Soul.
    Mods:<UL TYPE=SQUARE>
    <LI>Custom bent Flowmaster Exhaust....DEEP
    <LI>Alpine V12 Amp
    <LI>Two JL w0 x 12
    <LI>2 Color Indigo Gauges
    <LI>Spark Co. 9.2 mm Ignition wires
    <LI>Ford Blue Engine Cover[/list]
    Mods of the Month<UL TYPE=SQUARE>
    <LI>Hose Techniques Kits
    <LI>Esslinger UDP
    <LI>Esslinger Cam Gears[/list]
  5. #5
    Aug 2000
    Glastonbury, CT
    557
    Pitch,
    There is no change oil light on the foci.
    Igor
  6. #6
    Nov 2000
    Berwick, PA , USA
    124
    the oil is not even due yet. They dealer just checked the oil to reassure me that it was fine. They claim its something electronic or whatever.
    Is it true there is a red engine lite, and orange one? the dealer said mine is orange which means to me I can drive until Fridays appt.
    what is the code thing ?
  7. #7
    Apr 2001
    OKC, OK
    938
    Couple of things:
    1) Is your gas cap on tight. In some situation's, with some cars, a loose gas cap can cause the check engine light I believe
    2) In my previous car, when new, I put in premium gas (which I never do anymore, it's a scam unless your manual calls for it), and not far from the station, the check engine light came on. I was told, whether or not this is true, that cars that are to run on plain old 87 octane gas can be fouled up by the premium stuff
    Just curious if either of these two things may apply to you.
  8. #8
    Nov 2000
    Berwick, PA , USA
    124
    Premium does apply to me. Does this ruin the car for good? or just start using lower octane.
  9. #9
    Nov 2000
    Berwick, PA , USA
    124
    I have been using premium for a couple months now. never had a problem with it until now I guess
  10. #10
    Dev
    Dev is offline
    [FJ] OG Dev's Avatar
    Aug 2000
    (Devon)Citrus Heights, CA USA
    34,123
    Moving to Team Tech..
  11. #11
    Mar 2001
    Poughkeepsie, NY
    657
    jr,
    Your Focus is tuned for Regular Unleaded, 87 Octane. See your owners manual, or online at http://www.myfordfocus.com/underthehood.htm
    Also as seminole_kev said, it might just be that your gas cap is not on tight. I'm not sure which light that is however and/or if it's the one you see.
    Ray
    2001 ZX3 Owner
    [email protected]
    http://www.myFordFocus.com
  12. #12
    Nov 2000
    2,609
    Your check engine light comes on to tell you to have the dealer do a PCM Quick Test. The PCM is the computer that monitors and drives all the systems. Sometimes it will, and sometimes it may not, display on the dealers equipment something called a DTC or Diagnostic Trouble Code. If your dealer checked it and said not to worry till Friday, then I wouldn't worry and go see them on Friday. It can be one of a hundred odd codes. They will check it, fix the problem, or if it is a code that came on for something like the wrong octane gas or some sensor wire that fell off, then they will simply reset the PCM, the light goes out, and you are on your way.
    There is no way the computer knows if you changed your oil or not so don't worry about that suggestion.
    Unless you have an after market chip or some heavy duty mods to your motor, you are wasting money and not doing your engine any favors by burning Premium gasoline. The Zetec is designed for 87 Octane, use it. Don't worry about whether you caused any problems by using it; you didn't. It may or may not have set off the light...only PCM test will tell the tech that.
    Hope this answered your questions.
    Bobby
  13. #13
    Apr 2001
    OKC, OK
    938
    Yeah, you haven't done anything to damage the engine. Not to start the whole 87 vs premium debate, but 87 (from a regular gas station Texaco, Shell, etc) has the same additives to protect and clean your engine as premium. So as long as your manual says to run 87, which the Focus does, do it. Otherwise your just throwing away money. Don't feel bad, I did the same thing once.
    [This message has been edited by seminole_kev (edited 05-08-2001).]
  14. #14
    Nov 2000
    Berwick, PA , USA
    124
    Thanks Guys! I'll let ya know on Friday wats up with it.
  15. #15
    Nov 2000
    Berwick, PA , USA
    124
    just took my focus into the dealer today. Got the call just now, they seemed like they didnt want to go into much detail about it. They said the check engine lite is now off, but they needed to order a part (electronic part I assume). they mentioned it will not leave me stranded anywhere.
    anyone know what they might be talking about? Like I said they seemed to be reluctant to tell me exactly what this part does when I asked. They just said "its under warranty you wont have to pay a cent".
    Maybe when I get there they'll explain it more.
  16. #16
    Dec 2000
    (Rick) Cape May, NJ
    826
    I took my car into Ford today to have the CEL checked. Service manager told me it was the DPFE sensor that regulates the EGR valve and that it was no big deal. However, none in stock, of course. Will be un-Focused for another day!
  17. #17
    Senior TEAM Member jim01ZX3's Avatar
    Oct 2000
    Wilkes-Barre, PA | Jim
    2,468
    <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Hatchman:
    I took my car into Ford today to have the CEL checked. Service manager told me it was the DPFE sensor that regulates the EGR valve and that it was no big deal. However, none in stock, of course. Will be un-Focused for another day! <HR></BLOCKQUOTE>
    Damn! Same exact thing for me! Ahhh! DPFE sensors going bad left and right!
    Although, I have mine back today!
  18. #18
    May 2001
    Northwestern, NJ, USA
    568
    If you make some mods to your car, then you may need a higher octane gas. In stock condition name brand regular will do it, just fine. If you use a chip in you ECU, then you will most probably need 92 octane fuel. Although before I installed a chip I ran 89 octane and the car felt better and the mileage increase aboput .5mpg. So now you know.
  19. #19
    May 2001
    Seattle, WA, USA
    255
    Has anybody gotten recall on the DPFE sensor that regulates the EGR valve for 2001's. I checked the Blue Oval News site and there was nothing referencing this part...anybody aware of this?
    Let us know...Thanks!!!
    2001 RF Green ZX3, 2.0 Zetec 5-speed...17" Silver Quantum TEK rims, Federal 215/45R-17 Tires, Eibach Spings Pro-Kit, Borla Power Pack 2.5 Cat Back exhaust and Air Filter more to come...stand by!!!
  20. #20
    Nov 2000
    Berwick, PA , USA
    124
    fridays here still no part. Oh well!
    anyway, going down the road last nite, and the car is going at a very steady speed and a slow rate about 35mhp on a completely level road. The car seems to be pulling back than springing forward ....very,very slightly, just enough to feel, but not move RPM gauge much. any clue if this has to do with the sensor that may be bad on my 2001 Zx3??
