Grassroots Motorsports
Old 07-13-2001, 10:23 AM   #1
claypoolio
Default engine cleaning
How can i clean the engine without messing anything up?
00 Rainforest Green ZX3
Everyone dies,it's what you do when your alive that counts!!
claypoolio is offline   Reply With Quote
Old 07-13-2001, 01:24 PM   #2
smd3
Default Re: engine cleaning
correct me if I'm wrong, but the Focus doesn't have a distributor.
I spray mine off, and degrease. I just cover up my filter.
steve..
smd3 is offline   Reply With Quote
Old 07-13-2001, 02:57 PM   #3
claypoolio
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by smd3:
steve..
<HR></BLOCKQUOTE>
whatever the hell that thing is that all the spark plugs go in to.(damn i sound stupid)
Old 07-13-2001, 03:16 PM   #4
Bobby
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by claypoolio:
<HR></BLOCKQUOTE>
You have the right idea; the wires go directly to the ignition coil because the PCM does the work that the "distributor" used to.
As Linda said, just spray Simple Green on the engine (it's cheaper and less harsh than degreaser and works just as well). If you have an external aftermarket intake filter, just wrap it in a plastic grocery bag. Try not to hit any of the wires with a direct hit from the hose...sometimes you can knock them off doing that. I wash my engine bay about every other week and I don't cover the coil and it starts fine. If you do manage to get a little moisture under the plug boots, just wipe them off. Don't let the engine run crappy till the heat clears the boots; we could do that on older engines but on this one the CEL has a bad habit of coming on if the coil misfires to much, plus it's hard on the Cat. If you clean it regularly, you won't have to use heavy water pressure and worry about knocking something loose. I generally recommend running the engine for about 10 mintues after a wash job just to drive out water and moisture from all the little places it can collect.
Good luck.
Bobby
01 Yellow ZX3
Bobby is offline   Reply With Quote
Old 07-13-2001, 03:32 PM   #5
claypoolio
thanks Bobby,
that is what i wanted to know. My gf will be back at work soon and will be taking a class on tue. nights hopefully we can G2G at Hooters!
Old 07-13-2001, 03:44 PM   #6
Bobby
[ 03-19-2002: Message edited by: Bobby ]</p>
Old 07-13-2001, 05:25 PM   #7
cje2000
HOOTERS?! What, you guys keeping us out of the loop?
Cayson
Team South Florida
1968 VW Fastback
2000 Twilight Blue ZX3
Mods - K&N drop in filter, Iceman intake, Focus Sport plug wires, removed intake resonator, Progress springs, dome map light and variable wiper conversions, tinted taillights and turn signals, indiglo guage faces, and tinted windows.
1/4 mi.-16.3@83mph
cje2000 is offline   Reply With Quote
Old 07-14-2001, 12:04 AM   #8
Y2K ZX3
I am THE Focaljet MOM!
Quite a few months ago....Bobby recommended using Simple Green and it's been used on my engine area ever since...
Just spray it on....and let it do it's thing, and then just wipe off... if it's really dirty, repeat.... maybe scrub and rinse...covering up the wires.... hope this helped.
mom
linda
Y2K ZX3 is offline   Reply With Quote
Old 07-14-2001, 12:20 AM   #9
claypoolio
thanks Mom,
What i was hoping for was a list of things i need to cover up. I know about the distributor ,but what else.
Old 07-14-2001, 05:49 AM   #10
Bobby
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by cje2000:
<HR></BLOCKQUOTE>
You'd love it here when the Hooters Girls have their car wash and all the Foci line up for their bath
01 Yellow ZX3
Old 07-14-2001, 10:41 AM   #11
claypoolio
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Bobby:
<HR></BLOCKQUOTE>
Two words: Hooters everywhere!!
Old 07-14-2001, 11:35 AM   #12
cje2000
Damn! I smell a g2g! You should let us know when the next one is. I know the Hooters on Palm Beach Lakes blvd. over here hasn't had a car wash, wonder why? I may have to suggest that.
Cayson
Team South Florida
1968 VW Fastback
1/4 mi.-16.3@83mph
Old 07-14-2001, 01:49 PM   #13
claypoolio
beer,babes,and a clean ride!! life is good
Old 07-15-2001, 03:02 PM   #14
YellowZX3
I also clean my engine w/ simple green (thanks Bobby), but I leave the car running.
I've never knocked a wire off or covered the coil nor has it ever stumbled.
Maybe I've just been lucky so far...
YellowZX3 is offline   Reply With Quote
Old 03-18-2002, 04:38 PM   #15
SoCalFocus
I'm resurrecting this topic..
I cleaned my engine this weekend, covered all the stuff mentioned above, and my car is currently at the dealership cause my speedometer cut out, then my odometer, and now my check engine light is on.. could just be a coincedence, but I think I screwed something up. [img]images/icons/frown.gif[/img] It worked fine all yesterday and early this morning after i cleaned it, but when i went out running errands today, things just went bad. I'll keep ya posted on wtf happened.
SoCalFocus is offline   Reply With Quote
