Old 12-14-2001, 06:01 PM   #1
tuner1
Default Tools needed for front brake pad&rotor removal&install
Topic says it all,anybody want to help me out? [img]images/icons/smile.gif[/img]
tuner1 is offline   Reply With Quote
Old 12-15-2001, 05:44 AM   #2
lt7d101
Default Re: Tools needed for front brake pad&rotor removal&install
7mm allen wrench, slotted screw driver, wire coat hanger to hold caliper while you work on rotor, not sure on the exact size of socket to remove piece that caliper sits on, 13mm?, breaker bar, 3/8 ratchet. Easy install.
lt7d101 is offline   Reply With Quote
Old 12-16-2001, 12:19 AM   #3
j_latimer
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by tuner1:
Topic says it all,anybody want to help me out? [img]images/icons/smile.gif[/img] <hr></blockquote>
ok well what i used was a 45mm torx nut, with a 3/8ths ratchet, this was used to remove the 2 pesky screws on the caliper, no big deal after that, just release the pressure on the pads to the rotor, and your set there! then just pry the pads off, and your set!
j_latimer is offline   Reply With Quote
Old 12-16-2001, 02:41 PM   #4
tuner1
Thanks guys!
Old 04-04-2003, 12:37 AM   #5
sh0velman
can anyone post some specifics as to how you go about replacing the rotors and pads?
i have to do this friday night or saturday, and i would like some pointers...
also on the rears... i have no idea how to do that, but i know it needs to be done
sh0velman is offline   Reply With Quote
