Good old GOOGLE!
We recommend Mobil 1 synthetic engine oil, but not for break in (use a good quality mineral oil, not Castrol). Oil coolers should be equipped with a thermostat, and must be mounted vertically with the oil feed on the bottom. WARNING: If your previous engine experienced internal failure, you must replace your oil cooler. Oil coolers cannot be effectively cleaned of engine debris. Only factory filters should be used. Minimum running oil temperature: 200 degrees. Maximum: 260 (synthetic), 240 (mineral).
http://www.srsvw.com/engines.htm
I hope the above isn't for an air-cooled VW I didn't look to hard at the site.
For motorcycles I heard you wanted to be above 212F (boiling point of water) to get the water out of the lube system. Bikes may be differnt as the oil is both for the engine and tranny. Plus in my case, air cooled engine, it is for cooling as well.
