MBRP Inc.
Old 06-08-2007, 10:54 AM   #26
vor_tec330
Default Re: car wont start? click here! (troubleshooting guide)
thats the ignition fuse, the green one right?
vor_tec330 is offline   Reply With Quote
Old 09-20-2007, 07:43 AM   #27
20focus03
ok i got a question when i turn the key there is just a clicking sound coming from in the tranny (5pd) zetec.....what could it be it has a brand new clutch,battery and coil...starter relay?,solenoiD or starter itself?
20focus03 is offline   Reply With Quote
Old 03-10-2008, 06:29 AM   #28
glowboi87
Angry Re: car wont start? click here! (troubleshooting guide)
Just a heads up for all other focus owners with a manual tranny.....
the switches the gets pushed down with the clutch cause my 01 zx3 to not start. after replacing the starter... a few relays. and hours of labor and cut up arms... i found out that there is a switch that gets depressed when the clutch is pushed down and another that gets pressed down when the clutch reaches the bottom. well the metal piece on the clutch that holds a rubber circle type thing was bent a lil and wasnt pressing the 2nd switch at the bottom that lets the starter engage. so... after about 200 dollars... i found out that i could just bend the piece of metal
back with some pliers. wow... i noticed this prob wasnt up here so yup a heads up!!
after reading this thread over.. the 3rd question in the FAQS sums it up. lol easier than testing wires tho... i pushed the 2nd switch down all the way with my finger. yup. thank god for this forum tho.
glowboi87 is offline   Reply With Quote
Old 06-25-2008, 08:20 PM   #29
Turbo_Focuz
MY CAR WONT START
The car has been haveing problems starting i replaced the computer crank sencor the coils and the fuel pump when u disconnect the injectors the car starts and it shuts off becouse the car gets no fuel when the injectors are pluged in the car wont start i replaced the injectors also becouse it gets to much fuel the car is also turbo i replaced the injectors also
Turbo_Focuz is offline   Reply With Quote
