Old 05-22-2008, 09:19 AM   #26
Jeepsbeme
Default Re: Right front wheel noise
Originally Posted by n03ndinsight
he put little rubber gaskets inbetween the hubcap and rim, and it went away, but the rubber needs more adhesive so it only lasts about a week.
I wonder if he's using the right material and is installing it the correct location? Ford published TSB 06-09-05 for this and they were very specific about the type of urethane tape to use and where to place it.
Jeepsbeme is offline   Reply With Quote
Old 05-22-2008, 06:25 PM   #27
Jimmy
[FJ] Addict
gonna pray you didnt have hubcaps on your focus. my car does the whole ticking thing every time the wheel turns. the ford hubcaps are too large for the factory wheels, they push away where the wheel weights are on the bottom rotation, and snap back against the wheel weight on the upward rotation of the wheel weight. he put little rubber gaskets inbetween the hubcap and rim, and it went away, but the rubber needs more adhesive so it only lasts about a week.
mechanic at my dealership says someone comes in atleast once a month for bad wheel bearings, and they just got hub caps from the same run as my focus , and his fusion.
russ
Jeez...no, I dont have hubcaps. I would be LIVID if that was the case.
Well, they looked at the brake light and decided they didnt cause it (meh), but I had them run the brake diagnostic anyway since the ABS light has been on for about 4 years. They came back with a bunch of bad sensors, totalling about a grand in repairs...I said no thanks (actually told them up front I wouldnt be having it fixed). They also said after that stuff is repaired it should be scanned again to see if there were more codes that werent showing up.
Ugh.
LF sensor ring bad, RR sensor ring bad (this one I was pretty sure of), and two speed sensors up front. Gah!
They shall not grow old, as we that are left grow old.
Age shall not weary them, nor the years condemn.
At the going down of the sun and in the morning
We will remember them.
Jimmy is offline   Reply With Quote
Old 07-05-2008, 07:45 PM   #28
screwdiver
Ugh.
Sounds exactly like my situation. The front passenger side is making a lot of noise now and my e-brake light comes on and flickers on and off while I drive.
Recon = bad.
Ford Focus Hawaii
2003 Black ZX5
Mods: HID, LiveWires, Dirt
