Massive Speed System
Old 06-12-2008, 02:34 PM   #1
FocusOnPunk
Default Cracked spring safe to drive on?
I think I have the semi-common cracked front coil spring. When I turn the wheel, I get this loud, reverberating "clunk" (the reverb is what makes me think it's the spring). I also get this going over sharp bumps. Other than that, the car seems to drive just fine.
Is this safe to drive on temporarily? I can't get to the shop until next week, and need to drive somewhere this weekend.
FocusOnPunk is offline   Reply With Quote
Old 06-12-2008, 03:01 PM   #2
blueovaldave
Default Re: Cracked spring safe to drive on?
If the spring is broken it is not safe. The spring can easily come in contact with the tire which can cause a puncture.
You should be able to pull a wheel off and look and see if the spring is broken or not. If they do break they usually break towards the bottom and hang down below the spring perch.
2001 S2 Liquid Grey, PWSC
243 hp, 190 lb/tq
SPONSORS WANTED
"I may not have won alot of races, but I never lost a party."Ken Schrader
blueovaldave is online now   Reply With Quote
Old 06-12-2008, 03:11 PM   #3
FocusOnPunk
Unfortunately, I'm not able to jack the car up and remove a wheel where it's parked. Thanks for the advice on driveability though.
Old 06-12-2008, 03:43 PM   #4
Liquid_02_ZX3
not safe = get fixed ASAP
'02 Liquid ZX3 Power Premium MTX
4-1 header, custom 2 1/2" flex and catback, CAI, AFX crank pulley, A/C delete, custom Eibach Springs, KYB AGX's, painted 6 spokers, 225/50/ZR16's, B&M sts, Hurst knob, SVT cluster, Scangauge II, vac/boost & AFR gauges, 5% tint all arround, projectors with halo's, tail light covers, (2)12" Audiopipes w/3k watt amp, Jensen VM9512 headunit.
Liquid_02_ZX3 is offline   Reply With Quote
Old 06-12-2008, 03:58 PM   #5
Sharply_Focused
If you look at the spring, you should be able to tell right away if it's broken or not. Your car will lean to that side and you'll have coils touching each other.
I had this happen sometime before winter started and I couldn't afford to fix it until just 8 weeks ago. The car handled a little worse but in my case it was driveable. It may not have been the best idea to drive with it like that, but I had no money or choice in the matter. I needed to get to school and work. The problem was compunded by the fact that I use my car for work (pizza delivery).
It never gave me a problem. I believe the focus' coil springs are a variable coil package that tapers off as they move toward the spring seat. I think, the way mine broke, the smaller coils at the bottom broke into the larger coils above telescoping on itself and sitting nicely on the seat. I may have gotten lucky. Nevertheless it was still in the back of my mind the whole time to get it fixed.
Good luck.
2001 Egg Yolk ZX3
Glossy Sills & Triangles
30%F / 20%R Tint
Coming Summer '07: 2" Drop
Sharply_Focused is offline   Reply With Quote
Old 06-18-2008, 04:15 PM   #6
FocusOnPunk
Update: irrelevant, I got it fixed. It's under some lifetime or near-lifetime extended warranty.
Old 06-18-2008, 07:23 PM   #7
GapBoyPCS
It's actually an extended warranty. It's NOT lifetime, and it's only covering those of us who have specific model year cars and up to a certain mileage.
For example, Canadian vehicles were covered from 2000 to 2002 (I believe it's upped to 2003 and 2004, but I'm not sure), and it covered 10 years/240,000 km. Heck, I blew past that mileage and went right into the SVT suspension
To see if your vehicle is covered, any Ford dealer should be able to run your VIN through the database and detrmine if you have extended coverage. Owners on file with Ford should have already received the letter. Otherwise, you may have moved and/or have bought the car used, so Ford wouldn't have been able to notify you.
Richard - 2002 ZTS | Sangria Red | 386,000+ km...Be Bold, Stay Focused 24-7
OFOC - Ontario Focus Owners Club | SVTOA-Toronto | SVTOA Redline Rendezvous On Track
Old 06-28-2008, 08:41 AM   #8
UDonkey
I had this happen this morning on my '01 ZX3. I called the dealership and they ran the VIN - said that there aren't any "recalls" but that theres a bulletin and that they'll need to inspect my car on Thursday to decide what can be done.
I'm hoping my springs are covered - this is an expense that I definitely don't need right now.
UDonkey is offline   Reply With Quote
Old 06-28-2008, 01:03 PM   #9
Chaney
I think i still have my stock springs, I will have to check and see if they are in good condition. They have like 20k on them. If you need them Donkey, we can work something out for cheap.
Shoot me a pm, as i will forget I posted in team tech.
Chaney is online now   Reply With Quote
Old 07-01-2008, 12:07 AM   #10
FORDSVTPARTS
TEAM Sponsor
In the U.S. market the spring coverage is 10 years unlimited mileage for the affected vehicles.
We are Tousley Ford offering all OEM Ford and Ford Racing parts at 10% over cost.
PM me here or call Steve at 1-800-328-9552 during regular business hours.
2002 Silver SVT focus , custom CAI , Stage 2 throttle body, VF rear mount, FRPP 9mm wires, EAP/MACH HID's, Borla exhaust, K-W springs, FRPP UDP, Brisk LGS plugs, Screamin Demon coil, Diablo predator tune via Mike at Unique tuning. 153.27whp-140.56 lb.ft.
FORDSVTPARTS is online now   Reply With Quote
Old 07-01-2008, 03:19 PM   #11
Sharply_Focused
This is correct. I just went to the dealership today for an unrelated issue and even though I had my springs replaced elsewhere, they said they would work to get my money back for me! I was blown away. Bring it in and get 'em fixed FREE.
2001 Egg Yolk ZX3
30%F / 20%R Tint
Old 07-01-2008, 04:46 PM   #12
FORDSVTPARTS
TEAM Sponsor
If you want another neat trick you can also buy or bring in new struts and they will usually install them free with the new springs since it'll be fully disassembled anyways.
They'll only do that with OEM style struts though, I know of a few people that had that done.
Old 07-03-2008, 11:43 AM   #13
UDonkey
Just got back from the dealership - both front springs replaced for FREE on my '01 ZX3.
Thanks Ford!
