Re: A/C problems, etc.
Setting 3 is the most efficient way of cooling with the A/C on. Setting 2 isn't enough fan speed and 4 is too much speed not enough cooling. Normally setting 4 will work and 1,2,3 don't do anything. Setting 4 is a straight connection to the blower motor think of it as wide open if you will. While settings 1,2,3 go through the blower motor resistor. Maybe check the fuses or for a bad connection, but its definetly an odd problem you are having.
'02 Liquid ZX3 Power Premium MTX
4-1 header, custom 2 1/2" flex and catback, CAI, custom Eibach Springs, KYB AGX's, painted 6 spokers, 225/50/ZR16's, B&M sts, Hurst knob, SVT cluster, Scangauge II, vac/boost & AFR gauges, 5% tint all arround, projectors with halo's, tail light covers, (2)12" Audiopipes w/3k watt amp, Jensen VM9512 headunit.
