Ok so I've been doing a lot of reading and here is what I think I know as well as some questions that I still have.
Car Info:
2003 ZX3 2.3l non ABS, 90k on the odo.
Front:
My wheel bearing seem bad (slight groan, slight wiggle when on jack) My plan is to buy new hubs with bearings installed (I found some TimKens for 60 each)
Since I will be replacing the hubs there is no need to remove the knuckle?
I plan to get two new locking nuts as well and will inspect the spindle for gouges etc.
What else should I replace when I have it apart? seals etc?
I should have all the tools and from my understanding will not need a press.
What is the torque spec on the hub locking nut and should I appy any threadlocker?
Rear:
I am in need of new rear brakes and shoes anyways so will buy drums with new bearings. I think this is a pretty basic swap. Am I wrong?
THANKS!!!!!!!!!
Gage
Linear Mode
