Focaljet Store
Old 07-02-2008, 02:51 PM   #1
zeecks3
Newbie
Default Front Hub Nut
Any advice on removing this (explitive) thing?
I've proken two breaker bars and hit it with an air gun at 150 psi for a good half hour..................nothing!
Thanks folks
zeecks3 is offline   Reply With Quote
Old 07-02-2008, 06:34 PM   #2
TXFO
Default Re: Front Hub Nut
turn it counterclockwise.
how much reverse torque does the impact gun have? Get a good stout breaker bar and long piece of pipe and bust it loose! In 4 years of professional use, I've never broken my duralast breaker bar and Ive see the handle flex over 30*!
German and Italian car tech.
Chinese Democracy is badass. Get on the stick Axl, release it already!!!!
TXFO is offline   Reply With Quote
Old 07-03-2008, 09:44 AM   #3
grbrgrnzx5
Agreed! Is there evidence of rust on the thing? If there is, hit it with some PB blaster and let it sit overnight, that might help it somewhat...
Lookin' fast in the slow lane
RIP, Jellybean (11/16/2001-6/16/2008)...you will be greatly missed.
2003 Infra Red ZX3 SVT-Totally stock...FOR NOW!
grbrgrnzx5 is offline   Reply With Quote
Old 07-03-2008, 10:20 AM   #4
hEaT
Not sure if it's true for the Focus, but isn't one side right-hand thread and the other left?
Tuned By: Bristol Dyno
hEaT is offline   Reply With Quote
Old 07-03-2008, 10:49 AM   #5
OmniFocus
They're both normal RHT.
What can happen with a non-SVT Focus nut is the plates can expand and then the threads won't match from one plate to the next... so it grabs the threads of the axle and rips them off.
That is one reason I recommend SVT axle nuts instead of standard Focus ones... they are of a single piece construction with a captive washer.
Old 07-03-2008, 10:54 AM   #6
grbrgrnzx5
I like SVT nuts. Does that sound wrong?
The captive washer is nice, single-piece construction, no need to worry about the laminated plates separating from one another.
Old 07-08-2008, 08:39 PM   #7
smurf_with_a_focus
Location: In the 804.. But still representin' the 417..
I just took mine off a few hours ago.. hit it once with PB Blaster, let it soak for 5 mins then turned it with a 2 foot breaker bar and a hub nut socket from advance, came off like a charm. (it was non-svt)
who needs a sig anyway......
smurf_with_a_focus is offline   Reply With Quote
Old 07-09-2008, 07:51 AM   #8
Egz
My 300 ft-lb electric impact took care of them with gusto. But like said above, try soaking it in PB blaster first. And then try using a breaker bar with a 2-foot cheater bar on it.
Egz is online now   Reply With Quote
