Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > TEAM Tech
Old 06-28-2009, 04:51 PM   #1 (permalink)
Default Oil Filter Life
With synthetic oil the change interval is longer than with standard oil. But, will most oil filters still function as they should when their mileage greatly exceeds 3,000? One of the reasons I ask is that I have seen one filter that has it's replacement interval printed on the filter, but that is the only filter I have seen it.
TBP
Take_That_Subspace! is offline
Old 06-28-2009, 11:35 PM   #2 (permalink)
getn2focus's Avatar
Default Re: Oil Filter Life
I use a Castrol Full Synthetic. I can run about 5,000-5,500 miles for my oil change intervals. The Motorcraft oil filter holds up fine for that amount. I auto-x the car every month when I have the chance. I personally wouldn't let any filter go much longer then that.
Black 2003 SVTF >>> E Prep Auto-X monster
What to do when you roll a rental car in an auto-x? "You quickly roll/tow/carry it onto a public road and THEN call the rental agency." -- GtnMaZumOn
getn2focus is offline
Old 06-29-2009, 03:20 AM   #3 (permalink)
I Now Post Stupid ****
Jibberish18's Avatar
Depends on the design of the filter. I don't know what most filters SHOULD go to but some filters are designed specifically to hold more crud but those same filters don't filter as well as other filters that are designed to catch particles of a smaller size. Then again the filters that are suppose to filter better also don't flow as well. It's all a cycle.
"If You Never Had The Bad Times, How Would You Know You Had The Good Times?" -DEATH
Jibberish18 is offline
Old 06-30-2009, 07:49 PM   #4 (permalink)
Not Special Enough
TXFO's Avatar
this is a tough subject because there is alot of disagreement.
Porsche recomends 30k miles between oil changes and filter changes every 15k. (Porsches use 10 to 13 quarts of oil)
Mercedes was 15K on oil and filters every 5k.
Honda is 15 and 5
BMW was 10 and 5.
MB and BMW are now using FSS that moniters run time, mileage, and temperature to recomend when oil changes are due.
The thing to remember is the manufacturers want to push oil changes back because it lowers the yearly cost of ownership. This number has become more and more important as a selling point so anything they can do to lower this number, they will. Oil changes dont bother them because descent oil is going to do ok and by the time there is a problem, you are out of warrenty.
In my car, I run mobil 1 synthetic for 10k miles with no filter change in between. My engine has 170k miles on it and I have no sludge or problems so far.
German and Italian car tech.
Fixin to adjust the knob to HIGH POWERED.
black belt at the drunk as balls dojo.
Bloodshot eyes, metal skin, serpent's tongue, dagger claws, dragon wings, crooked horns. KING!
TXFO is offline
Old 07-01-2009, 08:46 PM   #5 (permalink)
TXFO: What filter are you using?
TBP
Old 07-02-2009, 07:06 PM   #6 (permalink)
Not Special Enough
TXFO's Avatar
motorcraft.
TXFO is offline
Old 07-02-2009, 10:38 PM   #7 (permalink)
I dont care what oil you use every oil change new filter. ITS YOUR ENGINE! not something that i would toy with. I personally like the napa gold filters
sportscarfan1989 is offline
Old 07-03-2009, 06:48 PM   #8 (permalink)
Not Special Enough
TXFO's Avatar
No body here said dont change the filter at every oil change. What I said was that some manufacturers recomend extended oil intervals with filter changes in between.
TXFO is offline
