Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > TEAM Tech
Old 09-21-2009, 11:49 AM   #26 (permalink)
Default Re: check engine light is on
um these things happen when you modify cars man. Could be your turbo took it out due to the higher pressures. If you wanted it to be reliable should of kept it stock.
<l><l>
2005 ses zx3 5sp- svt 5 spokes and sitting on SVT suspension, some other random stuff, DONE!
1988 supra- the new project..... now running and working out the kinks, just a lil faster than the focus
snake eyes is offline
Old 09-21-2009, 12:07 PM   #27 (permalink)
CHeck your connections at your AIT sensor and your MAF sensor. Those are the only sensitive changes you made to your car since the turbo right? I would start there just to be sure
Life is only what you make of it....And your car is only as fast as what you put into it.
Dave&KersFocus is offline
Old 09-21-2009, 01:24 PM   #28 (permalink)
Egz
Moderwhiner
Egz's Avatar
To be fair, you have modified the engine. You need accept that it will have quirks and small issues that will need to be solved. Its not Ford's fault.
Egz is online now
Old 09-21-2009, 04:18 PM   #29 (permalink)
I will check the MAF sensor. I have no idea what AIT sensor is.
PS. I got one code now it is P0106. The other two codes went away. It may be because I didn't clear the codes when I installed the O2 sensor even though the engine light was not on after it's installed.
Selling: 2007 Liquid Grey Focus ZX5
Mod list: FocusSport Stage 2 Turbo, Magnaflow 2.5" Exhaust, Eibach Sportline Springs, FRPP Dampers, Progress 22mm RSB, Steeda Tri-Ax STS, VF Rear Engine Mount, SVT Rear Brakes, Black EAPs and many more.
Look in Classified For Sale forum.
BoomBoy is offline
Old 09-21-2009, 10:12 PM   #30 (permalink)
Egz
Moderwhiner
Egz's Avatar
AIT is part of the MAF.
Egz is online now
Old 09-21-2009, 10:40 PM   #31 (permalink)
Randy said the trouble is not the MAF. It is MAP/Speed Density sensor that is in the intake manifold. He said I shouldn't have to take it off to replace the sensor. Any idea where I can find it?
BoomBoy is offline
Old 09-22-2009, 04:54 AM   #32 (permalink)
On the FSWerks kit you cut the wires to the stock MAF that controls your AIT and solder them to the Supplied AIT sensor they supply. Even though its still "part" of the MAF it is its own sensor on the FSWerks turbo kit located just before the throttle body and who is to say that it didnt go bad? Its just as sensitive as your MAF im assuming. BTW BoomBoy AIT stands for Air Intake Temperature Sensor
Old 11-06-2009, 11:32 PM   #33 (permalink)
Here is the update:
I replaced both oxygen sensor and MAP sensor and cleared the codes, but they came back on. The problem was not the sensors themselves. It could be wiring or the programming. I don't know.
The DTC codes are:
P0106 MAP CIR RANGE PERF
P0108 MAP CIR HI INPUT
PO132 OX S CIR H1 VOLT 1 S1
I took the car to the mechanic... they had no clue.
BoomBoy is offline
Old 11-10-2009, 12:44 AM   #34 (permalink)
Mabolzichjjl's Avatar
modded cars beg for this kinda stuff...
if they're made to run one way, and you're pushing them to run another, **** happens..
how does a mech not have a clue as to whats wrong! haha.. they should know these things!
sorry to hear about your luck. cant blame ford though
Mabolzichjjl is offline
Old 11-10-2009, 09:47 AM   #35 (permalink)
Have you checked fuses? I belive there is a power circuit that supplies both the MAF and your 02 sensors.
locdowg7 is offline
Old 11-11-2009, 12:01 PM   #36 (permalink)
I decided to reload the tuning program to see if it helped. It did, for a day. Now I just have P0106. I don't think it was a blown fuse. If it was, it would show up immediately, no?
It wouldn't hurt to check, though.
BoomBoy is offline
Old 11-11-2009, 02:37 PM   #37 (permalink)
Yup cuz speculation will bite you in the arss.
Next I would get some MAF cleaner and try that out be carefull not to break those little coiled wires inside the MAF.
locdowg7 is offline
Old 11-11-2009, 02:42 PM   #38 (permalink)
Oh and you dont have a MAP BARO is calculated by your MAF.
locdowg7 is offline
Old 11-12-2009, 10:16 AM   #39 (permalink)
MAF and MAP sensors are separate things.
BoomBoy is offline
Old 11-12-2009, 12:01 PM   #40 (permalink)
OmniFocus's Avatar
...and a Duratec car does indeed have a MAP sensor. It is located on the manifold near the throttle body.
Vacuum Vulture Racing: The masters of ape latexing.
OmniFocus is offline
Old 11-12-2009, 03:03 PM   #41 (permalink)
When I replaced the MAP sensor, I noticed the sensor had some dirt and grease on it. I don't know if some dirt was supposed to go through the manifold. I replaced it with a brand new MAP and then few days later the check engine lights up. Was it the dirt? Was the manifold somehow cracked?
I noticed a loose bolt near the belt assembly that secures the turbo piping. Some dirt apparently got in the belt assembly. Did the dirt get through all way to manifold? I secured it with a new, longer bolt because the stock one was too short to properly secure the turbo piping.
I checked all the turbo pipes and they were secured so I doubt some dirt got passed through to the throttle body. Thoughts?
BoomBoy is offline
Old 11-12-2009, 03:10 PM   #42 (permalink)
Hahaha... guess I got a little taste of my own prior medicine. I just sepculated that the new Duratec has an inferred BARO like most other Ford vehicles. Must be something that crossed over from Mazda.
Learn something new every day.
locdowg7 is offline
