| TEAM Tech Have a maintenance or DIY repair question about your Focus? Just ask! |
#1 (permalink) |
I only have 23,000 miles on the car. What could be the problem?
Selling: 2007 Liquid Grey Focus ZX5 Mod list: FocusSport Stage 2 Turbo, Magnaflow 2.5" Exhaust, Eibach Sportline Springs, FRPP Dampers, Progress 22mm RSB, Steeda Tri-Ax STS, VF Rear Engine Mount, SVT Rear Brakes, Black EAPs and many more. Look in Classified For Sale forum. |
#2 (permalink) |
Moderwhiner
There are hundreds of reasons why a code could be thrown. It could be as simple as the gas cap not being tight, or something seriously wrong with the engine. You need to take it to a dealer or autoparts store and get the code scanned so you know whats wrong. Almost sounds like you are still under warranty.
#3 (permalink) |
^^ That, or get your hands on a code reader.
I was going to say take it to the dealership. However, I didn't see you have modified your car significantly (turbo). A risk you may have in taking it to a dealer is that they may not cover your repair if your modifications caused the light to come on.
Richard - 2002 ZTS | Sangria Red | 433,000+ km...Be Bold, Stay Focused 24-7 Redline Rendezvous | OFOC - Ontario Focus Owners Club | SVTOA-Toronto [FJ] focaljet - Forum Guidelines - Welcome to the Jet - Team Canada - FJ Store - Sponsors - SEARCH |
#4 (permalink) |
I have turbo and a flasher. I could try flash it and see what code I get.
#5 (permalink) | |
I hope you don't mean you're going to flash/reprogram your car's computer now. Most of the time, when people say they are going to flash their ECU, they're implying they are going to wipe out and replace the program that's in there.
#6 (permalink) |
no i didnt reset the program.
i used a SCT Flasher. I set it to read DTCs. it threw two codes. P0108 MAP CIR HI INPUT P0132 OX S CIR HI VOLT 1 SI
#7 (permalink) | ||
Moderwhiner
Ah, didn't see you had a turbo either...
#8 (permalink) |
How do I reset the code?
#9 (permalink) |
Two ways:
1. Unplug the car's battery for at least 30 minutes. Hook it back up, start the car, and let the car relearn its idling (see owner's manual). 2. I'm pretty sure the SCT Tuner comes with a code clearing ability. Check the manual.
#10 (permalink) |
No need to un plug the battery....
In the Xcal there is an option to reset the codes....
"I was thinking the FS turbo kit but I absolutely have to have a BOV..." |
#11 (permalink) |
I used Xcal to reset the codes. Thanks everybody.
#12 (permalink) |
One week later, the engine light came back on. I checked the codes with the Xcal and got the same codes.
I suppose it is the bad oxygen sensor and I'll have to replace it. Edit: Does anyone know the part number?
Selling: 2007 Liquid Grey Focus ZX5 Mod list: FocusSport Stage 2 Turbo, Magnaflow 2.5" Exhaust, Eibach Sportline Springs, FRPP Dampers, Progress 22mm RSB, Steeda Tri-Ax STS, VF Rear Engine Mount, SVT Rear Brakes, Black EAPs and many more. Look in Classified For Sale forum. Last edited by BoomBoy; 08-14-2009 at 05:24 PM. |
#13 (permalink) |
Yea I still threw codes when my o2 went out, however the car ran like complete **** too. However yours just might not be there yet. Just grab an o2 at auto zone or something and your good to go.
Looking for a riding mower, snow thrower, push mower, weed wacker? Contact me, or email at LNservices@ymail.com Photoshop this euro kit and wheels on my car pleaz! http://forums.focaljet.com/focus-con...it-my-car.html |
#15 (permalink) |
always 93 octane. no cat on the car.
I cleaned the o2 sensor and cleared the codes. Lets see if it stays away.
#16 (permalink) |
The light came back on so I ordered a new o2 sensor.
The light is out as soon as I installed the new sensor. Few days later, it just came back on. What gives? Did I just waste $50?
#17 (permalink) | |
93 on a focus? srsly? i thought i remembered reading somewhere that the engine is made to run on 87. |
#19 (permalink) |
ah ok. so if you do something like that you need 93?
<----knows nothing about upgrading engines and what not. i am a strictly audio guy that knows a little about maintenance. i was just curious. |
#20 (permalink) | ||
#22 (permalink) |
I noticed that you have an 07 fofo. I have an 05 and i had to get my primary 02 from the dealer. They go off of your vin # and they are specific to your year and vin thats what the dealer told me. They are $80 at the dealer if you wanna pick one up. Seeing as how you live in Maryland im guessing you have only 2 o2 sensors and they are specific and different from one another as im told by Ford. Where did you buy you sensor from?
Life is only what you make of it....And your car is only as fast as what you put into it. |
#23 (permalink) |
I bought one from Steve from Ford Tousley for $50 shipped. They offer best deals on OEM and Ford Racing parts.
I scanned it and it got three codes: P0106 P0108 P0132 It didn't get PO106 the last time. The car is still running smoothly. I have no clue what trigged those codes. I don't know if it is serious or not. I cleared the codes yesterday and no code so far. Where can I get the info what the codes mean?
#24 (permalink) |
Moderwhiner
P0106 - Barometric (BARO) Pressure Sensor Circuit Performance Baro sensor input to the PCM is monitored and is not within the calibrated value. Slow responding BARO sensor
Electrical circuit failure Damaged BARO sensor Damaged PCM VREF voltage should be between 4.0 and 6.0 volts PID reading is in frequency
Duratec Wiki - Sign up and contribute! - [FJ] 2.3l Hatchback Social Group For Sale: Dome Map Lights - XM Roady - Differential - Crash foam - Blue Air Vents 2003 Ford Focus ZX3 2.3l N/A = 201HP, 157ft-lbs; 13.96@100.88 2006 Ford Fusion SE 2.3l Turbo = 244HP, 247ft-lbs, FSWerks Built |
#25 (permalink) |
So, I have another failure sensor? This ford is really a POS.
| Thread Tools | |
| Display Modes | |
