Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > TEAM Tech
Old 10-09-2009, 07:31 PM   #1 (permalink)
Default Check engine keeps on flashing
The check enine light and air bag,aand seat belt lights keep on flashing. I have replaced the airbag module and seat belts, so i dont know whats going on with that. The engine is fine so....
If anyone can help, it would be great. BTW the check engine light flashes about 6 times
Semir is offline
Old 10-10-2009, 10:23 AM   #2 (permalink)
GapBoyPCS's Avatar
Default Re: Check engine keeps on flashing
Have you gone and had your car scanned for whatever codes that might be causing the check engine light to flash?
Richard - 2002 ZTS | Sangria Red | 434,000+ km...Be Bold, Stay Focused 24-7
Redline Rendezvous | OFOC - Ontario Focus Owners Club | SVTOA-Toronto
GapBoyPCS is offline
Old 10-10-2009, 08:33 PM   #3 (permalink)
Im not too sure where i should go. Would a ford dealership do the trick?
Semir is offline
Old 10-10-2009, 10:24 PM   #4 (permalink)
GapBoyPCS's Avatar
A Ford dealership and most chain/independent shop should be able to read the codes. A dealership and a good shop would then take those code(s) and find out what's wrong.
*Okay..I just realized that you're probably posting about your car that you're trying to rebuild after a collision. Is there any chance you knocked something loose or broke something during your repairs? Given what you're doing so far, maybe you can pick up a code scanner (or justify getting something like an SCT Tuner Module that has a code scanning ability) and start to read codes as to what could be wrong. I know that with the air bag module, if something is wrong then the air bag light will flash a few times, and in a set sequence. I'm really wondering now is if some wires aren't crossed and/or something else got damaged during your repair.
Old 10-10-2009, 11:03 PM   #5 (permalink)
We checked everything, and replaced all of the broken parts. I think that the check engine light is on because it was time for an oil change?
The air bags, and module,and belts have been replaced, so im confused on why its still on.
Semir is offline
Old 10-10-2009, 11:47 PM   #6 (permalink)
NA Zetec Driver //// Where Bolt ons + Cams = 120whp
Semir, do this little trick, before turning the key to the ON position, press and hold the trip reset button. while holding it, turn the key to on. this will change the trip and odometer display and will tell you your DTC codes. that way you wont have to start the car (if its not able or unsafe too) to get the codes. you can report back here with the codes and we can help
http://www.focushacks.com/index.php?...gnostic%20Mode
Proud member of the 150k+ mile club
2001 zx3 crower stg3 cams/FC race header/2.5in exhaust/intake/tune/all poly mounts/H&R RACE springs/Koni sport yellow dampers/SVT RSB/CM stg3 clutch/CM lightweight flywheel/Torsen T2 LSD/SVT front and rear bumper/SVT grill and headlights /RS Wing/AEM UEGO
cjmartinyzx3 is offline
Old 10-11-2009, 11:14 AM   #7 (permalink)
GapBoyPCS's Avatar
The check engine light for a Focus is NOT a service maintenance indicator i.e. it's not something to tell you an oil change or filter change is needed. If it's ON, then something is not working right (well, at least the car thinks it's not working right). It can be a major system that's not working right OR it could be as silly as a sensor that's not plugged in all the way (so the computer is reading that something is wrong).
cjmartiny's trick MAY work; however, my understanding of the odometer DTC code trick is that it doesn't pick all the DTC codes fired off by the car's computer.
You do have the 2.0L Duratec engine, right?
Old 10-11-2009, 12:52 PM   #8 (permalink)
Yea, i have the 2.0 duratec. I just tried cjmartiny's trick, and it said GAGE
Semir is offline
Old 10-11-2009, 01:10 PM   #9 (permalink)
GapBoyPCS's Avatar
Keep pressing the odometer reset switch.
It's all there in that link that was posted.
Old 10-11-2009, 01:19 PM   #10 (permalink)
Yea, i just realized that. I presed it about 15 times, and all different codes came on.
Semir is offline
Old 10-11-2009, 01:56 PM   #11 (permalink)
GapBoyPCS's Avatar
Write the codes down and post them! That's going to be the only way we can all see what's happening with your car.
Old 10-11-2009, 08:09 PM   #12 (permalink)
Gage
leds
r 22
nr22
ee 1
dt6b
hr 387
cf1-20
cf2-00
cf3-00
cf4-00
DTC 9868
e0
0
59 77
t0
t9 48
f 28
fp 0
f9 151
sc
c9 131
odo 0
bat 113
Bf-0
nb-9
sl O
lc 100
cr-b
PO E
PO C
P3 80
P9 25
an 0136
an1 16
an2 0
an3154
an 4255
Thats a lot of codes...lol
Semir is offline
Old 10-11-2009, 08:34 PM   #13 (permalink)
GapBoyPCS's Avatar
Dang right that's a lot of codes. Everything up to the DTC appears "normal" from what's on FocusHacks. It's the rest of the stuff that really has me confused.
I can only assume some are Duratec-only codes. If anyone who has a Duratec can chime in on using the odometer diagnostic tool, PLEASE do so.
I know you generated lots of interest with your rebuild thread. Since you're in the Michigan area, maybe it's time to take up some offers and ask anyone in the area to drop by with a code scanner?
Old 10-11-2009, 10:10 PM   #14 (permalink)
I just found out that my friends dad is a mechanic, who has a code scanner. So thats good.
Semir is offline
Old 10-11-2009, 10:40 PM   #15 (permalink)
Damn it Semir, if i got some time wednesday or thursday, and you dont have the codes already ill come down with my xcal2 and we will get the codes
BTW thats not all codes, just the DTC stuff, should start with a P and then 4 numbers.
like P1000
Old 10-11-2009, 10:42 PM   #16 (permalink)
Ok cool
My friends dad said he can scan the car next saturday, so that is pretty good
Semir is offline
Old 10-13-2009, 08:05 AM   #17 (permalink)
was your car running while you did your codes?
it shows you are at 11.3v even if it wasn't your batteries are low..
Focus126 is offline
Old 10-13-2009, 02:53 PM   #18 (permalink)
My car was off, and the battery seems to be working fine. It starts the car up perfectly.
Semir is offline
Old 10-31-2009, 11:21 PM   #19 (permalink)
The guy told me that he cant find out whats going on with the check engine light. He told me that his code reader wouldn't read my computer because it was not connected to the engine wire. I think that his reader couldnt read it, because it was too old..haha
Oh well.
Btw, Focus126, the battery voltage goes up when the car is running, so its good.
Semir is offline
Old 10-31-2009, 11:26 PM   #20 (permalink)
GapBoyPCS's Avatar
Oh well.
Which guy?
Code scanners connect through the OBD-II port that's right by the inside fuse access panel. There shouldn't be a need for an engine wire, unless it's another type of code reader that I'm not familar with... All OBD-II scanners haven't changed within the last few years. Age shouldn't have anything to do with it -- if I recall, all OBD-II computers haven't changed in a while, and all are supposed to generate standard codes.
Old 10-31-2009, 11:29 PM   #21 (permalink)
It was my friends dad, he is a mechanic. He did hook it up into the right port.
Semir is offline
Old 11-01-2009, 09:28 AM   #22 (permalink)
Lancer211's Avatar
Oh well.
Is it very cold in Michigan right now? Because ambient temperature will cause the voltage to fluctuate.
Lancer211 is offline
Old 11-16-2009, 06:21 PM   #23 (permalink)
I got it scanned, and the light is off. The code is p0171.
For the airbag, did i have to replace the airbag sensor on the front bumper?
Semir is offline
