Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > TEAM Tech
Old 11-04-2009, 05:15 PM   #1 (permalink)
Exclamation IAT thrown Code and loss of vacuum. help!
let me start out by saying i have a 04 fsvt, with a procharger sc kit. Everything was running beautifully for months until on my way home from work one night in a rain storm. I would miss fire around 5psi of boost, from what i gathered this was from sucking in water from rain. then next morning i start the car and im getting a p0112 code iat low, i clear it drive it around get p0113 code. the car has a tremendous amount of loss power. and when im at idle more so when its cold when the ac pulley turns on i loose like 5psi a vacuum, as the car warms up its looses less and less but still i can here the ac pulley turn on sounds like a light psss sound.note the ac nore heat is on during this. Since the iat sensor is in the maf i took it out and cleaned it with electronic cleaner. I think the loss of power is from the iat sensor thrown code probably got wet and ruined, and i geuss ill have to get a new maf to fix that, but why am i losing vacum when the ac pulley starts to spin.
3rdgeneration is offline
Old 11-04-2009, 05:46 PM   #2 (permalink)
pzev04boy's Avatar
Default Re: IAT thrown Code and loss of vacuum. help!
Is your IAT sensor relocated? If so, replace the IAT sensor. If not you need a new mass air flow sensor. Or it may be a good time to relocate the IAT to the boosted side if you are draw thru but I believe the PC setup is blowthru. I would also recomend a K&N drycharger filter cover to prevent any future issues like this. Your loss of vacuum could be from the car running off from the IAT sensor issue. Running rich or lean at idle can affect how much vacuum you see. Don't get into boost till you resolve this issue.
I would invest in a wideband as well if you don't currently have one.
03 Zetec ATX E&S TURBO SYSTEMS powered sedan
00 Mustang Gt - Built motor - Soon to be Single turbo
07 Ninja 500R Building 640cc race motor.
pzev04boy is offline
Old 11-04-2009, 09:43 PM   #3 (permalink)
i geuss ill start with a new maf, see if that helps the ac vac problem. i understand that i would loose vac when the ac pulley comes on but there isint any reason why it should be on and it never did before until i started getting this code, hopefully a new maf is the fix all
Old 11-06-2009, 11:28 AM   #4 (permalink)
pzev04boy's Avatar
Did you know the a/c comes on when you use defrost?
Old 11-15-2009, 11:20 AM   #5 (permalink)
i did not know that! ill have to check that out,but even if its not blowing?
Old 11-15-2009, 12:40 PM   #6 (permalink)
No, not if it's not blowing. Interior fan has to be on.
Dato
And, if he still tries anything, use your l33t skills and un-dent his eye sockets.
CheaperSleeper
Why the hell can't women just "ding" like a microwave?
Scorpion is offline
Old 11-15-2009, 02:13 PM   #7 (permalink)
hmm thats not it then, ive fixed the thrown code but still having the ac pump problem
