| TEAM Tech Have a maintenance or DIY repair question about your Focus? Just ask! |
#1 (permalink) |
Newbie
Have a 2002 ZX-5 with Z-tec engine. Changed the valve cover gasket and noticed the new gasket came with rubber grommets. There was no grommets when i took off the old one. Do i need to use them and where do they go? Thanks in advance.
#2 (permalink) |
I <3 UC^3
Where did you get the gasket?
Sounds like you got one for the old Zetec with a metal cover. If you have a plastic cover, the grommets are not used. Did the gasket fit?
2001 Twilight Blue ZX3 - Volant Intake, FC 65mm TB, SVT Header, RT High Flow Cat, SVTF Borla Exhaust, Koni's 1985 Nimbus Grey Merkur XR4Ti - Work In Progress Tuned By: Bristol Dyno |
#3 (permalink) |
I was gonna say the same thing. That sounds like a gasket kit for the '95-'97 Contour Zetec.
For sale: Eibach Pro-Kit springs, sedan taillight, lower grille, DPFE, EVR, MAFS, side markers, trunk handle, fuel door, gas pedal, headlight switch, AC/vent/defrost button, hazard switch, ashtray, silver console bezel, HVAC controls. 2004 infrared Focus SE Zetec ATX sedan "Ruby" CarDomain Page |
#4 (permalink) |
not true..
if you are not getting oem stuff, it comes with grommets.. when i was in the states, i went to napa to grab and it came with grommets and it was for focus zetec, not contour/escort/mystique metal zetec..
Advanced MECP certified mobile installer 2000 Kona Dirt. www.cardomain.com/id/focusonfocus |
#5 (permalink) |
I <3 UC^3
You might find non-OEM gaskets still leak. I've had the best luck with Motorcraft valve cover gaskets.
| Thread Tools | |
| Display Modes | |
