MBRP Inc.
Sponsored by: The Tire Rack
Old 05-23-2001, 05:14 PM   #1
icemanZX3
[FJ] Addict
Default Motul brake fluid .......
www.motiveproducts.com has Motul DOT 3 and 4 brake fluid and other brands of lubrication.
There main item is an Automatic brake bleeder for $44.95...Now you wont need a second person to bleed your brakes..
Joe DeSalvo
RIDE: 2000 ZX3 Twilight blue,automatic.
GAS: FS plug wires,Esslinger UDP,blue oil cap.
BRAKE: EBC Green stuff pads
SUSPENSION: H&R springs, FS stress bar
EXTERIOR:window tint 20 and 35%,Nightshaded Taillights and turnsignals,debadged rear,FocalJet Banner,eyelids,APC headlight and Piaa marker bulbs,mesh grille,APC clear corners,euro plate, INTERIOR: Billet shift knob,indiglo gauges,blue shoulder pads front and rear,white painted dash pieces and center console,chrome fire extinguisher, removed backseat.
BUMPS: Sony CDX-M600,Sony Xplod faceplate.
icemanZX3 is offline   Reply With Quote
Old 05-24-2001, 01:45 PM   #2
icemanZX3
[FJ] Addict
Default Re: Motul brake fluid .......
el bumpo
Old 03-30-2002, 09:27 PM   #3
quale
Under their application chart, the Focus is not listed. All Fords with metal resevoirs are listed as a suitable application, however.
quale is offline   Reply With Quote
Old 04-01-2002, 10:38 AM   #4
FocusJeloSan
You can get the same bleeder from FocusPerformance: http://www.focusperformance.com/tpls/Detail.tpl?command=search&db=foccat.db&eqskudata=M P1000&cart=31005057903389
[img]images/icons/grin.gif[/img]
FocusJeloSan is offline   Reply With Quote
Old 04-01-2002, 10:43 AM   #5
FocusJeloSan
Anyone care to comment on which brake fluid would be good for lapping? I have my power bleeder, but I need to decide on a good fluid to use first.
In the meantime, off to search I go cuz I know someone's mentioned this before. [img]images/icons/smile.gif[/img]
Old 04-01-2002, 11:26 AM   #6
typ44q
I always use ATE super blue and gold fluid.
the MOTUL racing 600 is supposed to be very good but I have never used the stuff. the thing you want to look at is the wet boiling point.
Fluid DRY WET
Castrol LMA DOT 3/4 446 311
Ford Heavy Duty DOT 3 550 290
ATE Super Blue Racing 536 392
ATE TYP 200 536 392
Motul Racing 600 585 421
Castrol SRF 590 518
Performance Friction 550 284
the castrol SRF is the best (used in Indy cars!) but cost about $70 a liter
Mike
typ44q is offline   Reply With Quote
Old 04-01-2002, 11:30 AM   #7
typ44q
the formatting on my last post is totally screwed, there are supposed to be 2 collums with dry and wet #'s.
Fluid--------------------DRY----WET
Castrol LMA DOT 3/4-----446----311
Ford Heavy Duty DOT 3----550----290
ATE Super Blue Racing----536----392
ATE TYP 200--------------536----392
Motul Racing 600---------585----421
Castrol SRF--------------590----518
Performance Friction-----550----284
ok hopefully that makes it a bit easier to read
Mike
Old 04-01-2002, 05:44 PM   #8
FocusJeloSan
Great. Thank you. [img]images/icons/smile.gif[/img]
