Sponsored by: The Tire Rack
Old 11-16-2001, 09:51 AM   #1
JMcQueen
Default Tire Pressure
Does anyone know what the recommended tire pressure would be for 215/40/17 on a 7x17 rim? Mine look like they need some air but not sure what to fill them to. The car is normally unladen with only the driver.
JMcQueen is offline   Reply With Quote
Old 11-17-2001, 06:11 PM   #2
G1-Focus
Default Re: Tire Pressure
US pressure:
15" 32psi
16" 34psi
I would try 35psi for the 17". If the RS has 17" stock then find a dealer that sells them and look at the factory sticker with the proper inflation settings.
Hope this helps.
[ 11-17-2001: Message edited by: G1-Focus ]</p>
G1-Focus is offline   Reply With Quote
Old 11-19-2001, 11:03 AM   #3
Wickd68
38-40 psi no less u will run thee risk of bending a wheel also blowing the sidewall out of the tire. [img]images/icons/cool.gif[/img]
Wickd68 is offline   Reply With Quote
Old 04-29-2003, 03:09 PM   #4
furiousfocuz2G
I run 35psi all around on my Parada Spec 2's they are 215/40/17...........Seems to work well, not a single bend in my rims.......................Peace..........J.Lo
furiousfocuz2G is offline   Reply With Quote
Old 04-29-2003, 03:55 PM   #5
Stay Focused
Originally posted by Rob G:
yup, i know this is an old post, but i searched [img]images/icons/wink.gif[/img]
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by Wickd68:
<font size="2" face="Verdana, Arial">so is this what people with 215/40/17 tires are running with?
also... what should the pressure be with the rim OFF of the car, so that when the rim is put on the car, it'll be all set and driveable?
</font><hr /></blockquote><font size="2" face="Verdana, Arial">I'm running this size tire (Michelin Pilots) at 44 psi.
Stay Focused is offline   Reply With Quote
Old 04-30-2003, 12:24 AM   #6
Rob G
Rob G is offline   Reply With Quote
Old 04-30-2003, 12:54 AM   #7
rheacer
um. door sticker on my FSVT says 32 psi front
29 psi rear, with ContiSports. Seems to work pretty well. AutoCrossing I run 38 front 36 rear.
rheacer is offline   Reply With Quote
Old 04-30-2003, 12:58 AM   #8
s2d2
this is also dependent on the tire. go with the manufacturer's specs, they've burst and pinch-flatted enough of them to know
s2d2 is offline   Reply With Quote
