Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Closed Thread
Old 09-10-2005, 06:24 PM   #51 (permalink)
Default Re: A Focus-friendly tire diameter chart
i got a question. I was lookin through the roush catalog and the wheel and tire setup they sell says it comes with 17x7 wheels and 255/45/17 tires. doesn't make much sense to me. andyone else heard this and will it work, cause i don't think it will
kipp is offline
Old 09-10-2005, 08:09 PM   #52 (permalink)
Educating Mazda Owners One Thread at a Time
Nliiitend1's Avatar
I believe that you are correct.
Nliiitend1 is offline
Old 10-12-2005, 01:16 PM   #53 (permalink)
I run 225/45/17 Azenis RT-615s on my SVTF. I had some slight rubbing on severe (pothole) compressions when they were new, but haven't had any issues since a few weeks of daily driving had occurred. Now they don't ever rub, on track or on severe compressions.
I also saw a post on sccaforums.com that one guy running an STS Focus got 245/40/17 Hoosiers to fit. He had aftermarket wheels to get the offset just right to make it work, but it did. That would be most welcome for next season...
Carrera26 is offline
Old 10-23-2005, 06:58 PM   #54 (permalink)
KA1
what about 215-35-19
What he said!!!
KA1 is offline
Old 10-23-2005, 07:29 PM   #55 (permalink)
Hoosier doesn't make any tire that is STS legal. Also the maximum legal tire width in STS is 225.
CharlesWA is offline
Old 10-24-2005, 03:24 PM   #56 (permalink)
What if I want to add 17" rims on my ride which originally has 16" wheels? Would I have to reset the ECU to compensate for the changed diameter or are there tires that can accomodate the 17" rims yet still remains the same size in diameter?
ElCapo985 is offline
Old 11-12-2005, 01:59 PM   #57 (permalink)
Newbie
Can any one help a newbi.
I have a ford focus flexifuel hgv from 2004.
One like this:
http://img212.imageshack.us/my.php?i...73810010yg.jpg
I bought the car with 195/60-15 wheels and have now been offered a pari of snow wheels for free with the dimentions 175/70-14. Does any one know if these would fit or not?
jebo is offline
Old 11-23-2005, 03:48 PM   #58 (permalink)
Newbie
Do the tire sizes listed , fit all focuses (SVT, ZTS)? will 14" fit on ZTS (winter tires)?
Thanks
fos17 is offline
Old 11-23-2005, 03:54 PM   #59 (permalink)
Z63R's Avatar
14's will fit any 2000-2004 Focus except an SVT because of it's larger brakes.
All 2005 Focuses have larger brakes (but not as big as the SVT's 300mm's), so 14's may not fit on these.
Nobody's sure of the '05 ST as having 300mm brakes; I think they do.
Z63R is offline
Old 11-23-2005, 04:46 PM   #60 (permalink)
Newbie
Thanks for the quick response.. ford dealer says no for 2002 ZTS, but I thought they were just playing it safe.
fos17 is offline
Old 12-13-2005, 08:53 PM   #61 (permalink)
I have 235/40/17 on my SVT and have never heard them rub....
2003 Competition Orange #844
Steeda Springs, Eibach Swaybars, Steeda Camber Adj, Short Shifter, Cervinis Mid Wing, Body Pops and Clicks, Crappy Factory Stereo
comporange03 is offline
Old 01-18-2006, 01:31 AM   #62 (permalink)
DoubleStuf™
EDIT: Thanks to Z63R for pointing out that REV per MILE INFO IS INCORRECT. I am currently updating this table with the correct information. Sorry to anyone who I've inconvenienced. My original source was faulty.
In light of just having to adjust my speedo with my Xcal2 to read correctly with my new tire size, I thought I'd add a little value to this chart by adding the revolutions per mile for each tire size. I also noticed that most of the tire diameters were off by a tenth or so, and I corrected where appropriate.
Also, '05s do NOT have 300mm SVT front brake rotors. THey are a unique size inbetween the SVT & <'05 NON-SVT front rotors.
Tire Size ........ Diam. . Rev / mi
175 / 70 - 14 .. 23.7" .. 853
185 / 70 - 14 .. 24.2" .. 834
185 / 65 - 14 .. 23.5" .. 892- OE size
195 / 65 - 14 .. 24.0" ...892*
195 / 60 - 14 .. 23.2" .. 898-
205 / 60 - 14 .. 23.7" .. 852
215 / 60 - 14 .. 24.2" .. 835
195 / 60 - 15 .. 24.2" .. 859- OE size
205 / 55 - 15 .. 23.9" .. 835-
205 / 50 - 15 .. 23.1" .. 874
215 / 50 - 15 .. 23.5" .. 860
215 / 55 - 15 .. 24.3" .. 830
225 / 50 - 15 .. 23.9" .. 845
195 / 50 - 16 .. 23.7" .. 852*
205 / 45 - 16 .. 23.3" .. 895
205 / 50 - 16 .. 24.1" .. 863 OE size
205 / 55 - 16 .. 24.9" .. 836
215 / 45 - 16 .. 23.6" .. 854*
205 / 40 - 17 .. 23.5" .. 886
205 / 45 - 17 .. 24.3" .. 831*
215 / 40 - 17 .. 23.8" .. 874
215 / 45 - 17 .. 24.6" .. 846 OE size
215 / 35 - 18 .. 23.9" .. 866
215 / 40 - 18 .. 24.8" .. 840
I'M BACK FROM THE DEAD!!...........................................
Getting installed right friggin now as fast as I can crack the whip at the builder's ass:
T2 ATB, 4.06 fdr, Cosworth IM, Stg 2 Crane cams, Eagle ConRods, 12.5:1cr 88mm Supertech pistons, Fidanza FW
, Luk ProGold clutch, CFM Adj. cam gears
Installed: SVT Brakes, ST200 Rims, Koni Sports, -2" Apex springs, poly FLCA & dog-bone bushings, Progress 22mm RSB, TriAx/F STS, Cosworth CAI, Draxas & Trubendz exhaust, XCal2- *Now with more ProRacer!*
Oreo is offline
Old 01-25-2006, 08:40 PM   #63 (permalink)
In the spirit of being helpful, I've busted out the calculator and my 10 key skillz to compute revs/mile.
If you're going off of anything other than straight math, feel free to edit or remove this info.
ASSumption: 5280 feet per mile. 12 inches per foot. 5280*12=63360
Circumference=Diameter*pi inches
63360/circumference = revs/mile
175 / 70 - 14 .. 23.7" .. 851
185 / 70 - 14 .. 24.2" .. 833
185 / 65 - 14 .. 23.5" .. 858- OE size
195 / 65 - 14 .. 24.0" ...840
195 / 60 - 14 .. 23.2" .. 869
205 / 60 - 14 .. 23.7" .. 851
215 / 60 - 14 .. 24.2" .. 833
195 / 60 - 15 .. 24.2" .. 833- OE size
205 / 55 - 15 .. 23.9" .. 844
205 / 50 - 15 .. 23.1" .. 873
215 / 50 - 15 .. 23.5" .. 858
225 / 50 - 15 .. 23.9" .. 844
195 / 50 - 16 .. 23.7" .. 851
205 / 45 - 16 .. 23.3" .. 866
205 / 50 - 16 .. 24.1" .. 837 OE size
205 / 55 - 16 .. 24.9" .. 810
215 / 45 - 16 .. 23.6" .. 855
205 / 40 - 17 .. 23.5" .. 858
205 / 45 - 17 .. 24.3" .. 830
215 / 40 - 17 .. 23.8" .. 847
215 / 45 - 17 .. 24.6" .. 820 OE size
215 / 35 - 18 .. 23.9" .. 844
215 / 40 - 18 .. 24.8" .. 813
gobstopper is offline
Old 01-25-2006, 08:54 PM   #64 (permalink)
Z63R's Avatar
LOL; well, I didn't exactly say it was incorrect. I pointed out, in a PM to Oreo, what Hankook's website had posted for revs per mile and it was quite a bit different.
Now our friend gobstopper has posted yet different figures.
I quote Hankook's figures for the sizes posted for the Focus (in the original [FJ]stickied post) in 16 and 17 inch diameters:
205/50ZR16 87W Z212 24.1 862
205/55ZR16 91W Z212 24.9 835
215/45ZR16 86W Z212 23.6 879
215/ 40ZR17 87Y Z212 23.8 874
215/ 45ZR17 91Y Z212 24.6 843
I'm going to go with this tire manufacturer's figures for now, until we resolve this issue.
"I replaced the battery cables to the starter. I've been dreading it since the PowerWorks severely restricts access to the starter... A good job for a 6'2" 150lb pianist, but not so hot for a 5'10" 220lb wookie. - OmniFocus
2.3 Duratec ZX3 + some bits
Z63R is offline
Old 01-25-2006, 11:39 PM   #65 (permalink)
DoubleStuf™
Well, I believe Gobstopper's numbers are being calculated the same way my ORIGINAL information was calculated because those numbers look to be about the same. *Note that at the time of THIS posting, I've edited about half of the numbers in my previous post, so they won't match Gobstopper's.
For my corrected info, I have been getting my numbers from TireRack's tire spec's for various tires. All of those numbers (across different brands) seem to be consistent to within a few revs of each other for any given tire size. While I trust math to give an accurate number for an unloaded, non-spinning tire... I'm more willing to trust the manufacturer's specs to correctly reflect real-world performance.
Oreo is offline
Old 01-26-2006, 12:58 AM   #66 (permalink)
Z63R's Avatar
Well said, Sir.
And I am by no means casting any aspersion towards gobstopper's incredible mathematical skilZ.
Z63R is offline
Old 01-27-2006, 03:15 PM   #67 (permalink)
Originally Posted by Z63R
Well said, Sir.
I would also trust the manufacturers' specs, hence my disclaimer.
And I wouldn't call it mathematical skillZ as much as I'd call it remembering 7th grade geometry.
Now, my 10-key, on the other hand...
That's skillZ.
What's the airspeed velocity of an unladen swallow?
Old 02-27-2006, 01:54 PM   #68 (permalink)
RapMaster ConeBlaster
Falken makes an Azenis RT-615 that is 205/40r16. This would make it one of the smallest overall diameters in the list, but it has not been added. Can someone please add it?
Clickies: MySpace / CarDomain / SCR-SCCA / ProFlaggers
2005-2008 SCR-SCCA STS Champion
National F&C
Parting out my car. Jetters get first crack. Inquire within.
John B is offline
Old 03-04-2006, 10:52 AM   #69 (permalink)
i have 225/50-15 on my car...they work great and look wide too..i have no problem turning or anything...
got some mods. im gettin there
yellowfocus02 is offline
Old 03-06-2006, 10:31 AM   #70 (permalink)
What brand/model are they?
National F&C
John B is offline
Old 03-11-2006, 03:38 AM   #71 (permalink)
does anybody know what size tire to run on a 19" rim?
Your honda looks better in my rearview
Zx3vteckiller is offline
Old 03-13-2006, 08:48 AM   #72 (permalink)
Are they 19x7?
National F&C
John B is offline
Old 03-17-2006, 08:24 PM   #73 (permalink)
Thanks to everyone for the handy RPM/tire size guide.
For anyone dialing in their speedo to new tires via reprogramming, the most accurate way of knowing the circumference of YOUR tires at the pressure YOU run so that you can use the supplied formula is to mark the sidewall and make a mark on the ground at the mark. Now, drive the car forward until the mark comes around again, and mark the ground. The distance between the marks is the TRUE rolling circumference. If you do it ten revolutions and divide the result by ten, it should be even more accurate. Tread thickness, the 'squirminess' of the rubber, the pressure you run, etc, can all affect the rolling circumference.
On an unrelated note, I've found out that 205/40-17's just can't seem to survive Chicago potholes. I've dented two rims and seem to have broken a cord/belt internally in one of my Ecsta ASX's, so I'm moving up to 215/45's. I really wanted 225/45's, as I like how they look on WRX's, but it seems they probably would rub from what I've read on here.
Denny in Aurora IL
Inkedfireman is offline
Old 03-17-2006, 11:17 PM   #74 (permalink)
What about 19's?
Are you guys not even gonna think about including them?
zoom is offline
Old 08-01-2006, 11:53 PM   #75 (permalink)
ok kinda crazy here, but how about a 215/40r16?
or a 225/40r16
Some
Over worked
Honda
Originally Posted by TXFO
ladybug04 is offline
Closed Thread
