Sponsored by: The Tire Rack |
#26 (permalink) |
dont see any reason y not, just a question of findin the bloody parts. really dont want 2 move 2 a 16in rim. tire selection is limited, more exp, and i have 2 buy wheels (bleh)
wonder if the calipers could b shaved down like what mcnews did 2 get 13in rims up front. not likely but wishful thinkin never hurts. -Ult |
#27 (permalink) |
If possible, I'd like to see a side-by-side weight comparison between all these offerings. Itwould be nice to know how much weight you are adding/subtracting from each corner
#28 (permalink) |
FYI tidbit on wheel fitment, (if already covered my apologies) Baer states that their 330 mm track kit will work with most aftermarket 17" rims but not with SVT Factory 17" rims. I have personally used 17" Team Dynamics M/sports, 17" ASA AR1's and 17" Koenig Rush's with this kit and all worked perfectly, leaving room for tape weights anywhere on the rim they're needed. We tried 17" TSW Kylami's and not only did the fins on the caliper need filing off but there is a band around the rim were no tape weights will attach.
#29 (permalink) |
[FJ] Special Ed.
anyone got part numbers, for a person with 17's I wont have to worry about the clearance
btu does anyone have all the part numbers, spelled out so I can just print it and take it to Ford? |
#30 (permalink) |
Does anyone know if the BAER Front and Rear kits fit an Advance Track without upgrading the knuckles/spindles? If they don't does anyone know the part numbers for everything you would need from a SVT to modify?
#32 (permalink) |
Forget 'offset' it's wheel design that matters. It's all about the spoke clerance. Offset comes into play be short of a special order fit you need to review spokes first.
http://www.tceperformanceproducts.com/wheel_fit.html |
#33 (permalink) |
[FJ] Addict
TODD I GOT FROM PORSCHE WHAT YOU ARE LOOKING FOR! The rotors are in fact drilled BUT they have a cast dimples in them to make the metal flow and form around the area to be drilled to make them stronger. I cannot tell you my source but it is a very good one. We had a 2 hour discussion about this last weekend. James
#34 (permalink) |
Thanks for that update. We'd been over this elsewhere and seen both outer mold plates (with no holes) as well as the sand(?) castings for the inner sections to be broken out after the iron is poured. There are clearly rib reinforcements around the hole areas but the holes themselves are in no way cast into this part. This is the cast dimple you may be referring too. There were no dimples or pilot holes or such in the side plates however. If you want to read the whole thread on it shoot me an email. The pics were from the Move-it guys who apparently cast some of the parts for Porsche. And a Porsche employee did some research as well late in the whole conversation.
#35 (permalink) | |
[FJ] Addict
#36 (permalink) |
coming back to this. enzi (henry) asked if the stock pieces from a svt rear disc would clear w/a 15in wagon wheel over it. pirhana518 (laz), a ford tech, took a 15in wagon wheel for me and put it on a svtf that was in the dealer for service. it fits over the rear. i dont care bout the front, i'll keep that stock size w/better rotors and pads, that way fittin drag stickies on small rims w/no probs.
however, i NEED the list of p#s needed to complete the conversion of fitting stock svtf rear discs and pickups to the back of my zx3 to replace the drums. help anyone -Ult |
#37 (permalink) | |
I'll let you know how I make out. Here's my starting point from Tod's post above:
#42 (permalink) |
First off this is a very informative post by Todd. For my question, I was reading the article on the big break kit by BAT, and it says that you need to modify the stock front wheel hub. Does anyone know? What kind of modification they are talking about? And is the rear break kit also a direct bolt on, or will I need to modify?
#43 (permalink) |
you need to grind off some of the knuckle to use the caliper bracket that spaces the caliper further out so you can run the 300mm front rotors.
the rear, i believe is no modification other then unbolting the stock parts and bolting the new parts on. |
#44 (permalink) | |
#46 (permalink) |
i have actually been thinking about my brake options lately, from SSBC it is $900 for the rear disc upgrade and another $1700 for the front BBK kit. so i was considering the SVT brakes swap, then it hit me, i work with a buddy of mine who has a cougar, and the bolt pattern/offsets are the same, so i wondered how similar the brake setup could be and it is all wheel discs......i would assume the cougar's brake setup has larger rotors/better calipers than even the SVT focus because the car is so much heavier.....anyone have a clue if this swap is possible??
#47 (permalink) |
#48 (permalink) |
[FJ] Addict
The Cougar rear disk swap has been thought of since the Focus first came out, and it's still impossible to do. Don't waste your time.
As for the BAT kit... be careful with that one. Last I heard, they chose the wrong piston sizes in order to use some off-the-shelf Mustang calipers and the resulting pedal feel is bad.
Lefebvre Performance Engineering "I'd rather be right than consistent" - Winston Churchill |
#50 (permalink) | |
http://www.redlinetrackevents.com http://www.barberdrivingexperience.com *2008 GTI MKV*2008 F-150 FX4*2009 Focus Coupe* "That which you manifest is before you" - Garth Stein |
| Thread Tools | |
| Display Modes | |
