Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Closed Thread
Old 12-12-2005, 03:54 PM   #51 (permalink)
Default Re: Big Brake Kits: the options spelled out- Expanded version
Originally Posted by airforcefocus
It's the same for the SVT. I just test fitted a set of Mintex SVTF pads this weekend and they are identical to the ST.
While the caliper might be the same...
the knuckle is definetally different.
SVTs are 300MM and 05s & STs I thought were 278MM.
Larger then the 258mm 00-04 brakes, but smaller then an SVT?
2009 Ice White R-Design Volvo C30 : Strictly | Focused
myFlickr : Canon : Sigma : Tamron : Induro : Domke
[FJ] | Sponsors | Store | Guidelines | Ext. How-To | Int. How-To | Mid-Atlantic | [FJ]
DisrupTer911 is offline
Old 12-12-2005, 09:24 PM   #52 (permalink)
I 'believe' this is true. I've test fit an 04 and was satisfied that it all bolted up. The SVT parts that is.
However...I also noted that it appears the lower ball joint may be a tad larger on this part. Doesn't mean didly to me but you guys swaping parts around might find it a problem fitting the 04+ part on an earlier car. Dunno.
Less bling, more zing.
Todd TCE
www.tceperformanceproducts.com
Todd TCE is offline
Old 12-12-2005, 09:46 PM   #53 (permalink)
airforcefocus's Avatar
Yes, knuckle is different from ST, SVT, and standard ZX3. The ball joint IS bigger on the ST vs. early ZX3 and all SVT models.
I just swapped mine over on the 2001 ZX3 to ST front brakes and was looking at performance pad options.
http://www.redlinetrackevents.com
http://www.barberdrivingexperience.com
*2008 GTI MKV*2008 F-150 FX4*2009 Focus Coupe*
"That which you manifest is before you" - Garth Stein
airforcefocus is offline
Old 12-14-2005, 10:36 AM   #54 (permalink)
Can anyone post links to the sites, maybe on the first page? Would be really helpful. Thanks.
-Ryan
OneAMRadio is offline
Old 12-14-2005, 10:46 AM   #55 (permalink)
I can get the full SSBC setup for 1750 dollars. All 4 corners. 13" up front and 12" in back. I'll get a link to the website. The setup comes with Stainless Steel Braided Brake lines as well.
COSVT03 is offline
Old 12-14-2005, 10:49 AM   #56 (permalink)
Ford - Focus - 2003
Front Force 10 2-Piston Aluminum Caliper Disc Brake Kit
Part Number Description Retail Price Minimum Wheel Size Axle
A161 Disc brake kit with Force 10 SuperTwin 2-Piston Aluminum calipers and 13" rotors. Details $1,750.00 18" F
A161-2 Disc brake kit with Force 10 SuperTwin 2-Piston Aluminum calipers and 12" rotors. Details $1,675.00 17" F
Rear Standard Disc Brake Kit
A161-1 Rear disc brake conversion kit. Details $900.00 17" R
COSVT03 is offline
Old 12-14-2005, 12:00 PM   #57 (permalink)
Thanks! Question about that, what about brake bias? Front to back if I was to only go with rear disc brake kit?
-Ryan
Old 12-14-2005, 12:51 PM   #58 (permalink)
I think the SSBC kit uses a larger rear rotor then the stock front rotors on a NON-SVT so your bias is going to be throw off.
not to metion, having a 2 piston caliper in teh rear, vs a 1 piston in the front is going to throw it off as well.
if your gona do rears only, i'd either go with SVT rears or advancetrack rears.
Old 12-14-2005, 01:15 PM   #59 (permalink)
I won't be so bold to sepculate on what is or can change with regard to bias without some harder data.
On the surface of it, a 12" rear rotor is quite large. But if the front caliper is such that they have much greater piston area then things can come back to you.
Note however that any of these "two pot" calipers will still be floaters and not as responsive as a fixed mount part.
I can't see any reason for installing such a kit on the rear of a car without a properly matched front kit either.
Todd TCE
Todd TCE is offline
Old 12-14-2005, 01:34 PM   #60 (permalink)
Newbie
Hi, all. My English not well, but I hope you understand me and help. I have Focus 1.8L 115hp with rear drums(it's like yours ZX but with IB5 gearbox) and in Europe we have Focus ST170 (it's like yours SVT). I have read this topic and look Ford parts catalogand concluded that to install:
1)rear breaks from SVT I have to bolt on all AT car parts like:spindle, hab&bearing, caliper, hoses,pads, cables for handbrake - they all the same on SVT. But brake discs, caliper bracket only for SVT. Is it right?
2)front brakes from SVT. first of all I have to replace SVT wheel knuckle because of different SVT caliper dimensinons of tier? Somebody said that need to replace spindle but there is no spindle only hub and this hub the same for all cars except RS. Also I have to replace brake discs, calipers, pads only for SVT. Is it so? BUT I HAVE IB5 GEARBOX (as I know you have MTX75 gearbox). If I change front knuckle my hub fit to both joint and SVT knuckle? or if I buy SVT hub (but according to Ford catalog they are all the same) is it fit to my joint(IB5 GEARBOX)?
Thanks.
Ravel is offline
Old 12-15-2005, 10:10 AM   #61 (permalink)
Are the ST rear discs the same as the Advance track? I'd like to upgrade the fronts & rears to SVT, but am still wondering what all would be needed. I'll be putting my SVT Hawk HPS pads on the calipers front & rear probably this weekend, so will know for sure if they are a direct fit. I've read and searched, and found conflicting info. So since the ST lower ball joint is different on the knuckles than the SVT's, does that then mean you'll still need an SVT knuckle to fit the larger SVT discs on the ST? If not, then all I'd need for the front conversion, if the ST calipers are the same as the SVT calipers, would be the SVT caliper mounting bracket & SVT rotor?
Edit: I may just have to be the guinea pig, buy all the SVT front & rear stuff, and see what needs to be used & what doesn't. Oh well, someone's gotta be the first
JCM Racing #1
Chris
2005 cd silver ST 251whp 227.5tq
US spec Mk1.25 pioneer
Massive is offline
Old 12-16-2005, 10:36 AM   #62 (permalink)
Closed for housekeeping... I'm going to be cleaning up this thread over the weekend to get it back to being more informational and less conversational.
Todd - Shoot me a PM if/when you want any of your info updated.
CharlesWA is offline
Closed Thread
